Hi everybody,
I have a problem, I am using Raspberry PI like a master,but when i try to loggin and comunicate with it an error message appears :"[INFORMATION] Executing SSH command on e pi@10.1.3.40 e : Stop runtime system [ERROR] Error output: sudo: /etc/init.d/codesyscontrol: command not found [INFORMATION] Standard output: root
What could it be? How can solve the problem?
Hallo
ich habe den selber Problem gehabt. nach der deaktivierung der Applikation , hat es immer nicht geklappt.
kΓΆnnte ich bitte eine andere LΓΆsung haben?
I would first use the current version (4.0.1.0), if this is a PI4 will not work with 3.5.14.0 Runtime.
If these problems are still there with the current version, then we need:
cat /tmp/codesyscontrol.log
i wrote in command line for Raspberry : cat /tmp/codesyscontrol.log
but i get :
cat: /tmp: is a directory
cat: /codesyscontrol.log: No such file or directory
Hi everybody,
https://faq.codesys.com/display/CDSFAQ/Raspberry+-+FAQ
did you enable ssh one the PI?
Yes but nothing change.
Other solution?
we need more information,
does the runtime installation work? (CODESYS -> Tools-> Update Raspbberry Pi)
Screenshots whatever... more information is needed.
until a few days ago I had no problems and communicated with raspberry
and now I have this mistake that I have never seen before
I would try to disable the application... and restart the plc or the pi.
Last edit: eschwellinger 2021-06-06
Hallo
i don't use pi4 , i use PI2. i used first the current version (4.0.1.0) and i thought to change with this version 3.5.14.0 to get a solution
login by shh and give us the codesyscontrol.log
but i get :
maybe i don't do something very well
how can i login by shh ?
use 'putty' or any other ssh client sure you could this on commandline too.
use latest Raspberry PI Os and latest CODESYS Runtime then it must work!
