Thought I'd try using OOP with a system I'm making, more specific control of navigation lights for ships.
Every lit the same way, has feedback wether current is running when enabled (to check for open circuit), a set of customizeable presets (different combinations).
Is it overkill to use oop for such simple system or is it "ideal"? In that case could anyone point me in the right direction for how to divide each required component?
Let's say I've initiated a couple of navigation lights in a "light manager";
VAR  sb,port,aft,fwd,towFwd,towAft    :fbNaviLight;END_VAR
What's the best way of turning them on from a preset? Similary disabling them all?
I tried declaring them in an array then looping the array and that works, but it seems a bit cumbersome having to declare a light twice? And also the need of updating numOfLights.
  numOfLights : INT :=6;
  sb, port, aft, fwd, towFwd, towAft : fbNaviLight;
  naviLights : ARRAY [1..numOfLights] OFiNaviLight := [sb, port, aft, fwd, towFwd, towAft];END_VARIFdisableAllTHEN
  FORi :=1TOnumOfLightsDO
    naviLights[i].setLight(0);
  END_FOR
  disableAll :=FALSE;END_IF
IFDisableAllTHEN
  LigthOut :=FALSE;ELSE
  LigthOut :=LigthAsk;END_IF
Your FB will have the duty to manage a ligth, and how it is light up.
This ensure consistency along your program.
But as I/Os are independant, it is generally managed via FB I/Os, in a manner that you must affect it one by one.
you may also declare your I/Os directly as naviLights[i].LigthAsk and naviLights[i].LigthOut
OOP has many merits, but to some in the Automation world, the name and concept is dismissed. I have found that you can use many OOP concepts very nicely in CoDeSys. The ironic part, is the people that dismiss OOP are already using it when they use a function block!
What would be the best way to make lights and presets persisten/retain when working with OOP?
2018-03-05
If you want persistence, be a bit careful. If you define a variable inside of your FB as persistent, the whole FB will go into persistence memory. If your FBs are large or you have a lot of FBs or you have a very small amount of persistent memory, you will have a problem. In that case, create a method you call to pass an external persistent variable’s address to a local pointer or use REFERENCE TO (my recommendation). Instead of a method you can also use FB_INIT and force a reference link on instantiation. But I would start the simple way and let your whole FB go into persistence and worry about running out of memory if it actually happens.
Also be aware that some hardware platforms do not support persistence (Rasp Pi for example).
I tried declaring my function-blocks as persistent retain in declaration;
VARPERSISTENTRETAIN  sb,port,aft,fwd,towFwd,towAft    :fbNaviLight;END_VAR
But then I get a warning:
Zitat:
C0244: No VAR_PERSISTENT-list is part of the application to enter instance path for variable naviLightManager.sb
What's causing this.
2018-03-07
You should define your variables inside the FB as persistent retain, not the FB itself. I only mentioned that for compiler reasons, the whole FB will use retain space...
Program
Var
Light1, Light2 : MyLightControl;
End var
If Sunrise then
Light1.TurnOff();
Light2.TurnOff();
End if
If Light1.Service() then
Function block MyLightControl
Var
Temp : bool;
//other vars that don’t need memory
End var
Var persistent retain
LightIsOn : bool;
HoursOn : DWORD;
End var
2018-03-07
Originally created by: AntonZ
If you want to use persistance anyway without making everything inside the function block persistent:
Ok som more questions theyn.
To me there is no better case to use OOP. Every system is acting in a same way ...
I would use it this way :
FB code
Regards,
dFx
Related
Talk.ru: 1
Talk.ru: 2
Talk.ru: 3
Do you mean OOP is waste of time?
Also how do I take care of input and outputs in relations to this? As in where do I define them and where do I enable them?
What about methods and properties? When to use either of them.
CoDeSys gave a good example similar to your question. See these two CoDeSys store links:
https://store.codesys.com/object-orient ... re=default
https://store.codesys.com/object-orient ... __store=en
Thanks, I'll check those out.
I'm using Wagos PFC200 PLC.
Program
Var
End var
If Sunrise then
Light1.TurnOff();
Light2.TurnOff();
End if
Var
Temp : bool;
End var
LightIsOn : bool;
HoursOn : DWORD;
End var
