PROGRAM TestProg
Test: DINT;
Parent: FB_Parent(1234);
Obviously, this program does nothing but initialize a single variable, or should. The problem I'm having is that the Child.cVar (fairy syntax) doesn't have the value 1234, per my example.
Look at pragmas help. There are one called call_after_init or something similar. It doesn t work if it is called from a library.
There exist another method which is instantiate an fb from var. If you instantiate it as the first var in your fb, the fb_init of the new fb will be called before your variables initialization.
Be healty!
I'm having trouble with initializing function blocks inside of function blocks:
FUNCTION BLOCK FB_Child
cVar: DINT
END
METHOD FB_Init
VAR_INPUT
bInitRetains: BOOL;
bInCopyCode: BOOL;
SomeVar: DINT;
THIS^.cVar := SomeVar;
FUNCTION BLOCK FB_Parent
pVar: DINT;
Child: FB_Child(myVar);
METHOD FB_Init
VAR_INPUT
bInitRetains: BOOL;
bInCopyCode: BOOL;
SomeVar: DINT;
THIS^.myVar := SomeVar;
PROGRAM TestProg
Test: DINT;
Fb_init is called after the variables initialization.
See in online help how is the initialization sequence
Enviat des del meu Aquaris M5.5 usant Tapatalk
OK, thanks. I saw something that said FB_Init happened before VAR init.
What is the function/method decorator to have it called after init? I think that will work for me.
Thanks.
Be healty!
