I'm trying some code writing in codesys and testing it in simulation mode.
I need to try connection with a Modbus device (Arduino driven).
Is there a possibility to connect this device via Modbus TCP/IP to codesys simulation environment?
do not use simulaition for this you just need to start your plc on your machine.
Scan it and login to it.
Using a CODESYS control for Raspberry Pi for doing this would be an option too. https://faq.codesys.com/display/CDSFAQ/Raspberry+-+FAQ
Thank you very much!!!!
