Compile "everything"
schaepper
2018-01-11
2018-01-15
  • schaepper - 2018-01-11
    Hello together
    By default Codesys 3.5 SP11 (resp. all Versions) only compile and check code thats actually called. Is there a way to tell it to compile "everything"?
    Thanks for your informations!
  • singleton - 2018-01-11
    I have several possibilities in mind:
    1. Put all objects in the POU tree and call "Check all pool objects"
    2. Enable in the properties of an object "Link always"
    3. Create a global variable list and create an instance of those objects
  • schaepper - 2018-01-15
    Perfect, thanks for all the solutions!
