I saved it as the same project but in a different location.
I opened this "new project".
I clicked on the "Direct Login from Automation Builder" button.
It automatically directed me to CODESYS, where I was able to create the "Create Boot Project" but first I also clicked login again but inside CODESYS keeping the automation builder login online.
Additional Information:
The "Create Boot Project" function in CODESYS is used to create a project that will automatically start when the controller is booted up.
To create a boot project, you must first create a new project in CODESYS.
Once you have created a new project, you can then use the "Create Boot Project" function to create a boot application.
The "Create Boot Project" function will create a new application that is based on the current project.
The new application will be saved in the same location as the current project.
You can then download the new application to the controller.
View this messages about CoDeSys program
1) The file 'Config.ccf:' could not be sent
2) The file 'FlexConf.ini:' could not be sent
What's the problem? Its comunication error? The PLC cannot run
Thank you in advance
I have same problem.Can anybody know how to solve this problem?
Last edit: rathin1290 2023-02-21
I have same problem
