I've spent the day reading through the forums to seek a solution to my problem.
Perhaps I have missed something obvious which is why a solution eludes me...
I'm trying to run an executable file through my program POU.
This is what I've done so far.
PS: I made a button to launch the executable through the visualization and that works, so the file and the path are fine. I get no compile errors either and the rest of the program seems to run fine.
I'm working on Windows 7, in a simulation as I do not have access to a device just yet.
Note: The commented solution did not work either.
I hope you read my message! I am in S.O.S situation indeed . .
Actually, I have a big problem may be you can help me :
I am working on Windows 10 x64 and I need to execute a batch file in CodeSyS for some purpose
but SysProcess Execute Command is not working ! I have done these steps carefully:
1 -
CODESYSControl.cfg [SysProcess]
Command=AllowAll [SysFile]
Windows.WorkingDirectory=C:\ProgramData\CODESYS\CODESYSControlWinV3x64\801BFF8C
2 - Create a Py file
3- call Py file in batch file and test the bat.file to be sure if it works fine.
4- Create a POU file in codesys
IF fbTimer1.Q THEN
//Reset it and flash again
counter2 := counter2 +1;
fbTimer1(IN:= FALSE);
Test_2 := SysProcessExecuteCommand(pszComand:= Command , pResult:= ADR(dutResult));
Hello Team.
AND
why not using the installed Control Win runtime?
Thank you kindly for your response!
This was the obvious flaw in my program that I failed to understand.
In hindsight it makes perfect sense that to perform commands you
need to be logged into a device....
Everything is working now. Thank you again.
Hi @eschwellinger,
1 -
CODESYSControl.cfg
[SysProcess]
Command=AllowAll
[SysFile]
Command : STRING(200):='C:\Users\tsw08\Desktop\Bat.bat';
IF fbTimer1.Q THEN
This is my bat.file
and this is my Python script :
