masscard - 2017-12-12
Hi, we have developed a device that handle more than one axes (4 axis).
we tested it with our software and TwinCAT software and with standard PLC provide by software
all Axis are working correctly.
Our client, prefer you use your codesys system but we have same problem of integration.
When we try to configure the axis the variable your plc are not connected to processdata
entry.
We tryed to after import the xml we wolud like to connect softmotion to our system.
Attached is our xml.
Could you help us, if possible?
Thank Massimo
ISAC BridgeEtherCAT.GATEWAY_Rel1.1.1.TouchProbe.xml [90.21 KiB]
