It is currently Wed Jun 19, 2019 8:13 pm
PostPosted: Fri Dec 01, 2017 1:47 pm
I try to use VisuElems.cmpDynamictext.DynamicTextGetTextW function to read a text from text list.
In my project I noticed that it returns pointer to "" until I add a Visualization and select a language in the Visualization Manager. Then it works.
But my problem is I would like to use the function in a library and call it from inside the library.
The function called from inside a library always returns non-zero pointer.
I suspect this is because of language (I may be wrong), because for the library no language is selected.
I tried to set a language with VisuElems.cmpDynamictext.DynamicTextChangeLanguage function, but without success.
Does anyone have an idea how to resolve it?
PostPosted: Fri Dec 01, 2017 5:13 pm
From past experience when no "language" is selected I had to call DynamicTextGetDefaultTextW instead of DynamicTextGetTextW.
PostPosted: Mon Dec 04, 2017 10:45 am
Thank you for your reply, Comingback4u.
I have tried both functions (DynamicTextGetTextW and DynamicTextGetDefaultTextW), but both of them return pointer to an empty string.
Strangely, I noticed that if I put the text list in my project rather than in the library, then the functions call from the library return correct text.
I also called VisuElems.CURRENTLANGUAGE and DynamicTextGetCurrentLanguage functions inside the library and they both seem to have a correct language selected (same as in the project).
So my understanding now is: there is a problem with accessing/receiving the text from the text list from inside the library, because the text list placed in the project works.
I still do not know how to resolve it though.
PostPosted: Mon Dec 04, 2017 9:05 pm
I have not tried it in a library but can you check to see if the textlist is being put onto the device? The textlist might be adding the library name before it and can verify that by looking in the visu folder. For example you might need to call "library.txtlistname" instead of just "txtlistname". Just a thought.
PostPosted: Thu Dec 07, 2017 9:37 am
Comingback4u wrote:
(...) The textlist might be adding the library name before it and can verify that by looking in the visu folder. For example you might need to call "library.txtlistname" instead of just "txtlistname". Just a thought.
That was exactly what happened!
I had to add the library namespace before text list name, as the library adds its prefix with dot.
That resolved the problem.
Thank you very much for your support!
PostPosted: Mon Sep 17, 2018 8:35 pm
I know, the post is old! But ist there somebody who could tell me what's wrong?
I want to change the language but i couldn't do it.
I can see the language (Deutsch, Enlisch,...) i choose with a button in my visu.
But i can see no text from my textlist.
Thanks a lot. Greetings Timo
Ich freue mich besonders über die Besucher auf meinem Blog die auch einen Kommentar hinterlassen...
PostPosted: Tue Sep 18, 2018 1:32 pm
1. Use system variable VisuElems.CurrentLanguage to switch language from code (if you need it).
2. Try other quotes: 'library.Texlist_EBS', '0'
Make CODESYS great again
PostPosted: Tue Sep 18, 2018 7:46 pm
Thank you very much! The quotes fixed the problem!
Users browsing this forum: No registered users and 9 guests
