How to add custom baud rates to Modbus_COM serial device?
Anttie
2017-11-20
2017-11-25
  • Anttie - 2017-11-20
    Is it possible to add more "standard" baud rates to modbus_COM device? For example 460800 baud. Now the highest baud rate that can be selected is 115200. I'm using Codesys V3.5 SP11 Patch 3 and external USB serial device (/dev/ttyUSB0).
    IMG: Modbus_COM_device_baud_rate_options.png
  • RBS - 2017-11-25
    Not sure what you want to go that high, but you can look under Modbus RTU library or whatever Modbus you are using; but try that to see if it works;
    IMG: ModbusRTU.PNG
