It is currently Mon Mar 18, 2019 8:29 pm
PostPosted: Tue Nov 07, 2017 3:44 pm
Hello.
I have a PLC with one CAN interface wich is setup as a CanOpen Manager and it runs ok.
Now I also need to send and recieve some RawCan Data.
The PLC manufacturer states in the manual that supported libraries for CAN is:
CAA CiA 405, 3.5.8.0
In this library I cannot find any raw can function blocks.
But as CanOpen is a protocol on top of CAN there must be a way to send raw messages?
So can I use raw can?
How do I do this?
PostPosted: Tue Nov 07, 2017 6:45 pm
I'm not sure if this what you are looking for but in the past I have used "CAA Can Low Level Extern" (CL2) to send and read messages without using a manager. There is also the CAN API library in the store you can reference that I believe is built off CL2.
PostPosted: Wed Nov 08, 2017 9:42 am
I need the CanOpen manager for all my CanOpen nodes. But I also need to send and recieve some raw can messages on the same interface.
Is it possible to have a CanOpen Manager and to send raw CAN messages simultaneously?
As i said my PLC manufacturer states in the manual that only the library CAA CiA 405, 3.5.8.0 is supported for CAN and I dont see any RAW CAN FBs in that library. So I dont know if I can use the CAA Can Low Level Extern?
PostPosted: Wed Nov 08, 2017 6:08 pm
Yes you can still have the CANopen manager and any devices you add to it.
I understand what your manual says but it doesn't mean you can't try it. Both CL2 and/or CAN API. Possible solution > no solution.
