It is currently Mon Mar 25, 2019 2:54 pm
PostPosted: Wed Oct 25, 2017 8:41 am
Dear,
I'm upgrading my win RTE Target from 32 bit to 64 bit.
Most code seems to work with also in 64 bit.
However I get a build error that I do not understand how
to resolve.
------ Build started: Application: CODESYS_Control_RTE_V3.MultiControl -------
typify code ...
[ERROR] cmperrors interfaces, 3.5.5.0 (system): C0338: The Library 'cmperrors interfaces, 3.5.5.0 (system)' is only supported in 32 bit applications
Compile complete -- 1 errors, 5 warnings
My problem seems to bee with a library. So I tried to locate
the cmperrors interfaces in my Library Manager, but I cannot find it.
I do find some cmperrors2 interfaces in the library.
Am I supposed to install something ? What ?
Am I supposed to delete something ? What ?
Double clicking the error gives no linked place.
Thanks for advice
Best Regards
Magnus Torell
PostPosted: Wed Oct 25, 2017 5:59 pm
So,
Getting a bit further...
Not in the device "pane"/"tab", but in the POU pane I found
another Library manager, where there were some libraries ...23.
These were the problematic ones.
So instead I need advice how to replace the library SysCallback23
and the method SysCallbackRegister in 3.5 flavor.
I use it as:
SysCallbackRegister(ADR(CallbackNetVar), EVENT_STOP); (* ToDo 2 übersetzen in EVENT_STOP *)
SysCallbackRegister(ADR(CallbackNetVar), EVENT_BEFORE_RESET); (* ToDo 2 übersetzen in EVENT_BEFORE_RESET *)
SysCallbackRegister(ADR(CallbackNetVar), EVENT_DEBUG_LOOP); (* ToDo 31 übersetzen in EVENT_DEBUG_LOOP *)
SysCallbackRegister(ADR(CallbackNetVar), EVENT_BEFORE_DOWNLOAD); (* ToDo 31 übersetzen in EVENT_DEBUG_LOOP *)
Best Regards
Magnus Torell
PostPosted: Sat Apr 28, 2018 2:46 pm
Hello !
I face the same problem. I have updated the software to Codesys V3.5 SP12 Patch 3, but still the problem persists. I have tried with WIN V3 X64, RTE and Raspberry, but none worked.
                ------ Build started: Application: Device.Sim.Device.Application -------
                typify code ...
                Compile complete -- 1 errors, 0 warnings
                Build complete -- 1 errors, 0 warnings : no download possible!
Please help solve this issue.
Thank you in advance
PostPosted: Sun Apr 29, 2018 8:18 am
use Systypes2 Interfaces Library... for 32 and 64Bit Systems..
Users browsing this forum: No registered users and 21 guests
