It is currently Thu Jan 18, 2018 1:04 am
 Post subject: CAA NBS - NTP request
PostPosted: Thu Oct 12, 2017 11:00 am
Hi. I try to use CAA Net Base Servises (3.5.5.0) to get current time from NTP-server. My Device - CODESYS Control Win V3 (3.5.5.0).
NTP-server: 129.6.15.28 (time-a.nist.gov)
http://tf.nist.gov/tf-cgi/servers.cgi
I take example of NTP-request (0x1B and 47 NULL bytes) from this:
https://stackoverflow.com/questions/119 ... er-using-c
I test it with Hercules utility, and it works:
Now I want to make this with CODESYS Control Win V3 - and I can't get response from server.
And no errors in all NBS fb's.
Maybe somebody will be able to found my mistakes and describe it.
I will be really grateful.
My code:
   iStep:            INT;
   fbUdpPeer:          NBS.UDP_Peer;
   hPeer:             NBS.CAA.HANDLE;
   fbUdpSend:          NBS.UDP_Send;
   fbUdpReceive:          NBS.UDP_Receive;
   stNtpAddress:         NBS.IP_ADDR;
   abyNtpRequest:       ARRAY [0..47] OF BYTE:=[16#1B, 47(0)];
   abyNtpResponse:      ARRAY [0..47] OF BYTE;
   fbSynchroPeriod:      TON;
   fbTimeout:          TON;
fbSynchroPeriod
   IN:=NOT(fbSynchroPeriod.Q),
   PT:=T#15S
stNtpAddress.sAddr:='129.6.15.28';
CASE iStep OF
0:
   fbUdpPeer
      xEnable      :=   TRUE,
      ipAddr      :=      ,
      uiPort      :=   4023,
      ipMultiCast   :=       ,
      hPeer      =>   hPeer
   IF fbUdpPeer.xActive THEN
      iStep:=10;
10:
   fbTimeout(IN:=FALSE);
   fbUdpSend
      xExecute   :=    fbSynchroPeriod.Q,
      udiTimeOut   :=    ,
      hPeer      :=    hPeer,
      ipAddr      :=    stNtpAddress,
      uiPort      :=    123,
      pData      :=    ADR(abyNtpRequest),
      szSize      :=    SIZEOF(abyNtpRequest)
   IF fbUdpSend.xDone THEN
      fbUdpSend(xExecute:=FALSE);
      iStep:=20;
   20:
   fbTimeout(IN:=TRUE, PT:=T#6S);
   fbUdpReceive(
      xEnable   :=   TRUE ,
      hPeer   :=   hPeer ,
      pData   :=   ADR(abyNtpResponse) ,         // fixed
      szSize   :=   SIZEOF(abyNtpResponse) ,       // fixed
   IF fbUdpReceive.xReady THEN
      iStep:=10;
   IF fbTimeout.Q THEN
      iStep:=10;
END_CASE
PostPosted: Fri Oct 13, 2017 5:05 am
I found my mistake and edit first post. Now it works.
