Integrate C# Code in Codesys
Basta87
2017-09-28
2017-10-09
  • Basta87 - 2017-09-28
    Hi guys,
    i have a question about C# Code Integration in CODESYS.
    What do I need to integrate C# Code in CODESYS (Visual Studio 2015, Visual Studio 2017)?
    It is also possible to integrate C# with Visual Studio Express ?
    Can you give me an example how to integrate C# Code in CODESYS?
    Thanks in advance.
  • Anonymous - 2017-10-02
    Originally created by: rickj
    Since C# runs on CLR, a non-realtime VM, there is not much chance it's possible to do what you ask.
  • schaepper - 2017-10-09
    You can run C / C++ on a PLC which supports this, as far as I know. Then you could use Visual Studio, but it will still not be C#.
    If you are used to C# and are now doing IEC-61131-3 with what ever hardware, welcome in the late 70ties, early 80ties. They just disocvered hashmaps and unittests!
