Good day, my friend!
Can you help me in one question.
In ST language if you write S= or R= is function like Set and Reset Relay in LD language.
May be for rising and falling edge in ST exist specific symbol, for example : If <Contact THEN ... "<" - like Rising edge.
I ask you, because not comfortable create another variable, remember mean at the end of cycle, and compare in next cycle, like this: If lastContact<Contact THEN... like Rising edge.
If you know about this some interesting information, please, answer me.
I don't think this is possible because one is kind of an operator and the other is a function block that needs to remember the old value in order to detect a change.
Zitat:
Ok, but how it is realizΡ in ladder diagram? program remember all variable old value ?
Yes, in LD the variable of type R_TRIG or F_TRIG (from Standard.library) is declared implicitly (automatically and invisible for user).
ST has no such "service", you have to declare them implicitly.
Regards,
Roman
Hi BIZON,
Regards,
Roman
