rising and falling edge in ST, like < >
BIZON
2017-08-30
2017-08-31
  • BIZON - 2017-08-30
    Good day, my friend!
    Can you help me in one question.
    In ST language if you write S= or R= is function like Set and Reset Relay in LD language.
    May be for rising and falling edge in ST exist specific symbol, for example : If <Contact THEN ... "<" - like Rising edge.
    I ask you, because not comfortable create another variable, remember mean at the end of cycle, and compare in next cycle, like this: If lastContact<Contact THEN... like Rising edge.
    If you know about this some interesting information, please, answer me.
  • teichhei - 2017-08-30
    I don't think this is possible because one is kind of an operator and the other is a function block that needs to remember the old value in order to detect a change.
    Sent from my SM-G935F using Tapatalk
    Ok, but how it is realizу in ladder diagram? program remember all variable old value ?
  • r.evbatyrov - 2017-08-31
    Hi BIZON,
    Yes, in LD the variable of type R_TRIG or F_TRIG (from Standard.library) is declared implicitly (automatically and invisible for user).
    ST has no such "service", you have to declare them implicitly.
    Regards,
    Roman
