I'm a CoDeSys beginner. I already found for some of my previous problems solutions in this forum. Maybe you can help me with my current problem.
As hardware I am using the MTX-Control from Bosch Rexroth. It is a CNC with integrated CoDeSys V3 PLC.
I want to search a file in a directory. If this file is available, I want to create a new folder and copy this file into this folder. Additionally I want to delete an old folder which contains old files.
I've included alread the SysFile.lib but with this lib I can only copy a file, but I cannot search a file, delete one or create a new folder.
Does someone know which library I have to include for this purpose? And how an example code must look like?
I hope you can help me.
Thank you
Martin
I found a library which is able to delete folders and copy files.
I added the following two libraries
CAA File 3.5.9.0 and
File Acces 3.5.7.0
And created DirRemove, which I want to use to remove a folder.
varDirRemove:File.DirRemove;End_Var
But if I want to start the simulation on my programming pc I get an error message:
Error during download
15 unresolved references
The device version on the hardware seems to be different from the device version used in the project. Try to up-/downgrade the device in the project to match the actual version on the hardware.
In the messages window I get 15 additional errors:
ID Description
TaskList Unresolve Reference: 'Ticks_GETTICK'
and so on
Does someone know what I can do?
Hello
Thank you
Martin
Hello
File Acces 3.5.7.0
ID Description
and so on
Get the update
w www.boschrexroth.com/indraworks w
Gesendet von iPhone mit Tapatalk
