Breakpoint at the beginning
DawidS
2017-07-20
2017-07-20
  • DawidS - 2017-07-20
    I'm debugging my library. I can set breakpoints during debugging. This works well. I have the problem with the setting breakpoint in function which is run ones at begin program. When I login, application stop and I can toggle breakpoint but when I click start, the program does not stop at this breakpoint. It looks like some part of the code (where the breakpoint exists) is executed after login.
  • josepmariarams - 2017-07-20
    Hi.
    All initialization code (all fb_init for example) is executed before run, and as I can know it is not possible to make an breakpoint.
    I had the same problem with a library, and I solved it using log messages
    Josep, thank you very much for your reply.
    Could you give advice how can I use log messages?
    Hi.
    See this discussion
    l viewtopic.php?t=7517 l
