In Features&Improvements I see "File transfer supported in web-visu" and in online help I see "by default, not supported in web-visu". What mean "by default"? Will you release the File Transfer Example in Store?
Will you release the Visu Elems Library Example in Store?
When you plan to release Memory Tools Addon?
I suggest to improve interface variables in VisuDialogs.library with WSTRING instead STRING (similar like CDS-51209).
Zitat:
1. In Features&Improvements I see "File transfer supported in web-visu" and in online help I see "by default, not supported in web-visu". What mean "by default"? Will you release the File Transfer Example in Store?
2. Will you release the Visu Elems Library Example in Store?
3. When you plan to release Memory Tools Addon?
4. I suggest to improve interface variables in VisuDialogs.library with WSTRING instead STRING (similar like CDS-51209).
will post an example here / 3.5SP11 Runtime is needed
Need to check
ready, but waiting to be published in the store as package
will check if possible
attached the example project for tranfering file via Webvisu to the plc and vice versa
guess there are some bugfixes in for 3.5SP12
you need to add the following config file entry either to
CODESYSControl.cfg or maybe better to CODESYSControl_User.cfg if your system does support this splitted config file Extension.
CODESYSControl.cfg or maybe better to CODESYSControl_User.cfg if your system does support this splitted config file Extension. [CmpWebServerHandlerV3]
AllowFileTransferServices=1
Dear Edwin,
I'm trying to run this demo on CODESYS Control Win V3 (3.5.11.30). I've found CODESYSControl.cfg located in C:\ProgramData\CODESYS\CODESYSControlWinV3\D5050FE1. It contained only "[SysFile]". After adding the entry you suggested I still get Error Code 7 on Web Visu. Did I edit the right config file?
Hi. Some questions about SP11:
Edwin, do you have any news about Memory Tools Addon / examples?
Want to ask again, will it planned to release examples for File Transfer and Visu Elems Library in Store?
at the moment not,
for webvisu filetransfer I maybe could provide an example.
Yes, please, provide File Transfer example.
FileTransferDemo.project [179.38 KiB]
Edwin, can you resave this project in SP11, please?
Because common users does not have SP12 until 20.12, I guess.
yes but just open it save it with SP11 ..
Reopen it with SP11 will work too.
Dear Edwin,
