I'm trying to build a program which scan an alarm table and if an alarm occurs, it send a sms but I've a trouble with my Rtrig, so this is the piece of programm which give me problems:
For i:=0 to 200 by 1 DO
Rtrig(alarme[i].state)
If(Rtrig(alarme[i].state) THEN
buffer[j].mesage:=alarme[i].message;
J:=J+1;
END_FOR
So the problem is when a RTrig occurs, my programme continue stay in the IF, so it continues to store the same message in my buffer and it continues to increase the J variable
So I made a small test, after the for, I put a Test:=Test+1; and my variable Test increase continually until I release my variable Alarme[i].State
After that, I made a trial, I write a function in ladder language, with a R trig contact and a coil, and here it's working
Any help?
Thank in advance
Sorry, but your solution is too convoluted (difficult).
Usualy simpler is better, so try this;
Fori:=0to200by1DO
  Rtrig(CLK :=alarme[i].state); Run trigger function call
  If RTrig.QTHEN   // .Qistheoutputofthetrigger
    J:=J+1;
  END_IFEND_FOR
Hermsen,
The problem with this is that you are using the same R_TRIG for 201 values. So like teichhei says you would need an array of R_TRIG. For example if you had the following:
alarm[0]:=FALSE;Rtrig(CLK:=alarm[0]);Â Â Â Â //Rtrig.Qwould=false;alarm[1]:=TRUE;Rtrig(CLK:=alarm[1]);Â Â Â Â //Rtrig.QwouldALWAYSgettriggeredtoTRUEbecauseyouarecallingthesamefunctionblockasinline2;
So every cycle would trip the rising trigger.
You would need to do something like
//SUDOuntestedVAR
  alarm:ARRAY[0..200] OFBOOL;
  alarmTrig:ARRAY[0..200] OFR_TRIG;
  i:INT;END_VARFORi:=0to200by1DO
  alarmTrig[i](CLK:=alarm[i]);
  IFalarmTrig[i].QTHEN
   //doworkhereifalarmtriggered
  END_IFEND_FOR
Hermsen hat geschrieben:
Teichhei,
Fori:=0to200by1DO
    J:=J+1;
  END_IFEND_FOR
Don't think that would work because in every loop run you call the same instance of rtrig again, 200 times in a cycle, causing it to look at the previous condition in the previous call. But you need to trigger on the previous cycle state foe the same [i]. You are looking at a different value from one i to the next.
Well after reading the feedback on my posting I see why my solution will not work.
However, the anwser Joseph proposes seems very sound.
Good luck and sorry for the misdirection =) never too old to learn.
Hi everyone,
J:=J+1;
END_FOR
Any help?
Thank in advance
If alarme(i-1) is false and alarme(i) is true rtrig returns true.
You would need an rtrig by every i
And you are calling the block twice, should be If rtrig[i].q then ... So use an array of r_trig one for each alarm
Teichhei,
Hermsen,
Related
Talk.ru: 1
Good feedback!
Hi.
But the oop solution is create an fb alarm with three attributes.
Private bool alarm, edge.
Amd two methods
SetAlarm(bool value)
If(value<>alarmOld)then
Edge=true
Else
Edge=false
Endif
Alarm=value
And two gets, one for alarm, and one for value
That would work to.
I like the OOP version too...
