It is currently Fri Jul 21, 2017 11:30 pm
 Post subject: Using TCP Client
PostPosted: Fri May 19, 2017 2:55 pm
Hi all,
I would like to create a connection to an TCP server. I tryed to use CAA NetBaseSrv 3.5.8.10 (NBS.TCP_Client).
ServerIP.sAddr := '192.168.5.100';
Client(
   xEnable:=TRUE ,
   xDone=>TCPClient_xDone ,
   xBusy=>TCPClient_xBusy ,
   xError=> ,
   udiTimeOut:=5000 ,
   ipAddr:=ServerIP ,
   uiPort:=2000 ,
   eError=>TCPClient_eError ,
   xActive=>TCPClient_xActive ,
   hConnection=>TCPClient_hConn );
Somehow i get an 'timeout' right away. xActive never gets TRUE. Im sure the TCP server is ready to receive connections.
Am i missing something on the device configuration side? I also tryed to add '3S ethernet adaptor' and set the interface (PCI\E1R1). Doesn't seem to help. Controler = Lenze 3200C
If someone could point me to the right direction that would be nice!
Kind regards,
 Post subject: Re: Using TCP Client
PostPosted: Mon May 22, 2017 1:56 pm
Try connecting with putty to the server ip on port 2000 to make sure you can get a connection from your PC.
Also make sure that Lenze 3200C supports NBS.TCP_Client/Server and not just the standard SysSocket functions
PostPosted: Tue Jul 04, 2017 7:51 pm
that timeout is also in microseconds, so 5000 microseconds = 5 milliseconds is a bit too low. Probably increase to 500000 microseconds. If you ping device on your computer and the response takes 10ms, then setup connection for 100ms.
