It is currently Thu Jul 27, 2017 1:32 pm
 Post subject: WITH .. DO?
PostPosted: Thu May 18, 2017 12:08 pm
Does anybody know if there is some Codesys OOP variant of the WITH statement?
This type of statement would be usefull when initiliasing objects or setting more then one property at the same time.
pseudocode example;
WITH <object> DO
.<PROPERTY1> := Value1;
.<PROPERTY2> := Value2;
.<PROPERTY3> := Value3;
.<PROPERTY4> := Value4;
END_WITH;
 Post subject: Re: WITH .. DO?
PostPosted: Wed Jun 07, 2017 5:25 am
pseudocode example;
WITH <object> DO
END_WITH;
PostPosted: Wed Jun 07, 2017 11:20 am
var
    obj: <object>;
    p: pointer to <object>;
end_var
p := adr( <object> );
p^.<PROPERTY1> := Value1;
p^.<PROPERTY2> := Value2;
p^.<PROPERTY3> := Value3;
p^.<PROPERTY4> := Value4;
PostPosted: Wed Jun 07, 2017 2:07 pm
You could also use the REFERENCE data type instead of POINTER
var
    obj: <object>;
    R: REFERENCE TO to <object>;
end_var
R REF= obj;
R.<PROPERTY1> := Value1;
R.<PROPERTY2> := Value2;
R.<PROPERTY3> := Value3;
R.<PROPERTY4> := Value4;
PostPosted: Fri Jun 09, 2017 2:03 pm
The above options will do the trick I guess! thank you for the response!
Users browsing this forum: Andreas Kehrer and 1 guest
