It is currently Tue Oct 17, 2017 2:50 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Wed May 17, 2017 8:01 am
Is it possible to indirectly address memory,input and outputs the way you can do i Siemens Step7?
In step7 you can do MW[x] or IW[x] for example. In codesys it seems that you can only do it absolute, %MW0 %IW0 and not %MW[x].
Is there any way to accomplish this in Codesys?
PostPosted: Wed May 17, 2017 9:59 am
If you mean like fiddeling a dint into a byte array or so I do that with pointers.
PostPosted: Wed May 17, 2017 10:07 am
no not that, i mean when you are directly addressing the input/output/memory area.
i Siemens you can for example do:
FOR idx:= 0 to 4 DO
variable := variable + MW[idx];
LOOP;
That doesnt seem possible in codesys since you can only direcly adress input/output/memory with %MW0 or %MW10 for example, but you can't use brackets to indirecly adress
I would like to be able to do exactly the same:
FOR idx:= 0 to 4 DO
variable := variable + %MW[idx];
LOOP;
But thats not possible it seems and i can't find any information about indirect addressing if i google it..
PostPosted: Wed May 17, 2017 10:38 am
Have you tried putting your data into an array?
arr1: array[0..3] of byte;
Then you can enter your data into the array:
arr[0] := ...
arr[1] := ...
After that you can just do the for-loop like you did before.
for i := 0 to 3 do
variable := variable + arr[i];
end_for
PostPosted: Wed May 17, 2017 2:10 pm
I see what you mean. Would be interesting to know.
But couldn't you still do something like
paWord := adr(%mw0)
for idx...
variable := paWord^[idx]
In that way you should still get the content of the first, 2nd... word within the loop
PostPosted: Wed May 17, 2017 4:24 pm
You can do:
IW_in:pointer to word
IB_in:pointer to byte
After
IW_in:=adr(%iw0)
IB_in:=adr(%iw0)
After
A:=ib_in[4] Reads %iw4
B:=in_w[5] Reads %IB5
PostPosted: Wed May 17, 2017 4:39 pm
What situations require reading direct memory locations? I've never needed this and I am curious. Or is this old-school PLC techniques/habits?
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Thu May 18, 2017 11:43 am
*very* old school habit
PostPosted: Fri May 19, 2017 8:21 pm
Hi.
I don t know if it is an school habit, but it helps me in the problem of how to work from OOP point of view with inouts.
If you have an FB wich modelizes an pneumatic cillinder you need, normally, two Dinputs and two DOutputs. From my point of view this inouts have to be internals to the FB_CILLINDER.
For me every DInput is an FB wich has three configurable variables: channel, mask and inverted (that I configure using an csv for every di). Dinput has an boolean output with the value of the physical digital input:
Out:=(xb[channel] and mask) <>0.
It allows me to solve how pass from an sigleton (di) to Oop. And allows me to change without recompile the connection from an logical input to an logical output. Allows me to reconfigure diferent machines with only one code (versioning, rapid prototyping....).
PostPosted: Mon May 22, 2017 1:39 pm
Josep M. Rams wrote:
You can do:
After
IW_in:=adr(%iw0)
IB_in:=adr(%iw0)
After
Thank you, i had no idea you could use index on pointer without the pointer being an array. It works perfect though.
I know this is a really old school way of doing things but i have some S7 code and i want the codebase to be as similar as possible in codesys ;)
PostPosted: Mon May 22, 2017 2:16 pm
Not all CoDeSys controllers support direct addressing. For the one that do you would locate your variables as follows:
myBool  AT %MX0.0 : BOOL; //Boolean Type
myInput AT %IX0.0 : BOOL;
myOut   AT %QX0.0 : BOOL;
myByte  AT %MB0   : BYTE; //Byte Type
mySINT  AT %MB0   : SINT;
myUSINT AT %MB0   : USINT;
myByteArary AT %MB0 : ARRAY[0..10] OF BYTE;
myWORD  AT %MW0   : WORD; //16 bit types
myINT   AT %MW0   : INT;
myUINT  AT %MW0   : UINT;
myWordArary AT %MW0 : ARRAY[0..10] OF WORD;
myDWORD AT %MD0   : DWORD; //32bit Types
myDINT  AT %MD0   : DINT;
myUDINT AT %MD0   : UDINT;
myReal  AT %MD0   : REAL;
myDwordArray AT %MD0 : ARRAY[0..10] OF DWORD;
mySTRING AT %MB0 : STRING;  //STRING
Also attached is a useful memory map. It is excel file because calculates the memory map
The Original SoMachine Ninja
PostPosted: Wed Jun 07, 2017 7:23 pm
I understand the need to link a software BOOL to a physical real output. But for this I use the hardware IO mapping table of EtherCAT or other fieldbus device. Often, I have to shift around modules and when I do, the memory address changes and I do not want to care about this!
I use FBs with FB_INITs with REFERENCE TO for linking speaking software variables to physical outputs. This example I simply have a BOOL "ActOutput" which I map to an EtherCAT digital output. This forces the link at instantiation without any memory location hard coded. If I insert a module or move the module - CoDeSys handles the memory locations for me.
Original system has Digital Output 0 at %QX0.0. Second screen shot is after inserting a module, which shifts Digital Output 0 to %QX6.0 (for which I can completely ignore - it just works).
Here is an example of my Digital Output with REFERENCE TO:
PROGRAM PLC_PRG
   ActOutput : BOOL; //define at memory location, or use hardware IO mapping
   DigOut1   : DigitalOutput(refOutput:=ActOutput); //referencing is required by fb_init
   Temp1     : BOOL;
   Temp2     : BOOL;
DigOut1.TurnOn();
Temp1 := DigOut1.State;
DigOut1.InvertedLogic := TRUE;
Temp2 := DigOut1.State;
END_PROGRAM
FUNCTION_BLOCK DigitalOutput
   InternalState : BOOL := FALSE;
   ActOutState   : REFERENCE TO BOOL; //init not necessary - FB_INIT forces referencing
   Inverted      : BOOL := FALSE;
METHOD FB_INIT : BOOL
VAR_INPUT
   bInitRetains : BOOL; // if TRUE, the retain variables are initialized (warm start / cold start)
   bInCopyCode : BOOL;  // if TRUE, the instance afterwards gets moved into the copy code (online change)
   refOutput   : REFERENCE TO BOOL;
//link local var to real life BOOL
THIS^.ActOutState REF= refOutput;
END_METHOD
METHOD TurnOn
VAR_INPUT
THIS^.InternalState := TRUE;
UpdateState();
END_METHOD
METHOD TurnOff
VAR_INPUT
THIS^.InternalState := FALSE;
UpdateState();
END_METHOD
METHOD Toggle
VAR_INPUT
THIS^.InternalState := NOT(THIS^.InternalState);
UpdateState();
END_METHOD
METHOD PRIVATE UpdateState
VAR_INPUT
IF THIS^.Inverted THEN
   THIS^.ActOutState := NOT(THIS^.InternalState);
ELSE
   THIS^.ActOutState := THIS^.InternalState;
END_METHOD
PROPERTY InvertedLogic : BOOL
GET
InvertedLogic := THIS^.Inverted;
SET
THIS^.Inverted := InvertedLogic;
UpdateState();
END_PROPERTY
PROPERTY State : BOOL
GET
State := THIS^.ActOutState;
SET
THIS^.InternalState := State;
UpdateState();
END_PROPERTY
END_FUNCTION_BLOCK
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
