It is currently Fri Jul 21, 2017 11:32 pm
PostPosted: Fri May 12, 2017 5:41 am
Hi everyone,
I'm working on codesys V3.5.8 and I have this error message: "Connection denied by device: All available communication channels are already in use"
My plc is on a switch and it communicate with a touchscreen and I made a vizu, now I m not able to etablish a connection with this PLC
I can ping it, I can reach it with fttP://AdresseIP ; I can see the vizu and the touhcscreen still communicate with it
I saw on a board that I had to add this line in CODESYSCONTROL.cfg
[CmpChannelServer] Buffersize=1600000 MaxChannels=8
I added it at the end of the file but it's still not working
So if someone knows what I have to do
Many thanks in advance
Dom
PostPosted: Fri May 12, 2017 6:27 am
you should solve the root cause: Identify the program/application which does not release the channels
in a correct way.
First I would check in the plc shell which applications are connected:
Usually one of them does not close the communication channels in a proper way.
PostPosted: Fri May 12, 2017 6:49 am
Thank you for your quickanswer
It's since I've added the visu that I'm not able anymore to etablish a connection with my PLC, I make a trial with channel Info, it has worked 2 times and after the third time, I had this error message:
But if I'm plug directly in my plc (so I unplug all the other devices), I can etablish a connection with it
Any other idea?
PostPosted: Fri May 12, 2017 8:42 am
I continue my investigation
I've a switch with 1 TS, My plc and the network, if I try to etablish a connection here, it doesn't work but if I unplug the network, it works
The weirdest thing? I changed nothing in my hardware configuration and before it was working without any problem
The only thing I change I change my codesys version to 3.5.7 to 3.5.8
PostPosted: Fri May 12, 2017 9:40 am
maybe these are are old bugs which have been already fixed in newer version.
Do you have the chance to update your runtime and CODESYS Development System to currrent version (3.5SP10Patchx).
