It is currently Fri Jul 21, 2017 11:35 pm
PostPosted: Thu May 11, 2017 7:55 pm
Hi all.
My MAIN_PROG code consists of an initialization part, in which some files are read from txt files and stored in arrays, and an operative part in which values are used.
It should run on the RTE module and should receive and send data through my CIFX card on a profiBUS. I've coded and tested it in simulation mode (card is installed at my university laboratory) a Function Block that reads a txt file in which there is a matrix; so if the file is in the form:
1 2 3
4 5 6
7 8 9
it produces a bidimensional array containing those values. The program is executed in a standard cyclic task and it is the only one executing.
Well, in simulation mode everything works; while passing to the real run on RTE, files never get read, so returned arrays are always zero.
By using a step by step debugging, I discovered that the instruction:
FileHandle := SysFileOpen(szFile:= FileName, am:=SysFile.AM_READ, pResult:=pResult);
always produces the result: RTS_INVALID_HANDLE, even if in simulation mode this doesn't happen.
How can be this problem solved? Here is the code of the function block:
FUNCTION_BLOCK MATRIX_READER
VAR_IN_OUT
   M: ARRAY[*,*] OF INT;
VAR CONSTANT
   MAX_BUFFER : __XWORD := 64*1024;
VAR_INPUT
   FileName : STRING(255) ;
VAR_OUTPUT
   nRows : INT:=0;
   nCols: INT:=0;
   ErrCode : SysFile.SYS_FILE_STATUS := SysFile.SYS_FILE_STATUS.FS_NO_FILE;
   BytesRead : __XWORD := 0;
   Data : ARRAY[0..MAX_BUFFER] OF BYTE;
   pResult : POINTER TO SysFile.RTS_IEC_RESULT;
   FileHandle : SysFile.RTS_IEC_HANDLE;
   pFileData : POINTER TO BYTE := ADR(Data);
   actualValue:INT;
   values : ARRAY[1..10] OF INT;
   i: __XWORD;
   r_index: INT;
   c_index:INT;
   char: STRING;
   numEnd: BOOL;
   accString: STRING;
   minus:bool:=false;
   rowEnd: BOOL;
FOR i:=1 TO MAX_BUFFER BY 1 DO
   Data[i]:=0;
END_FOR
//try to open file
//verify found a file
IF FileHandle = SysFile.RTS_INVALID_HANDLE THEN
   //no file found
   ErrCode := SysFile.SYS_FILE_STATUS.FS_NO_FILE;
ELSE
   //try to read file out
   BytesRead := SysFileRead(hFile:=FileHandle, pbyBuffer:=pFileData, ulSize:=MAX_BUFFER, pResult:=pResult);
   //check if actually read any bytes
   IF BytesRead > 0 THEN
      ErrCode := SysFile.SYS_FILE_STATUS.FS_OK;
   ELSE
//close file!!!!
SysFileClose(hFile:=FileHandle);
r_index := 1;
c_index := 1;
accString:='';
minus:=FALSE;
i:=0;
WHILE i<=BytesRead DO
   IF numEnd AND BYTE_TO_INT(Data[i]) = 45 THEN
      minus:=TRUE;
      i:=i+1;
   numEnd:=FALSE;
   //new line or space
   IF BYTE_TO_INT(Data[i]) = 10 OR BYTE_TO_INT(Data[i]) = 32 THEN
      IF NOT(accString='') THEN
         M[r_index,c_index] := STRING_TO_INT(accString);
         IF minus THEN
            M[r_index,c_index] :=-M[r_index,c_index];
         minus:=FALSE;
         numEnd:=TRUE;
         accString:='';
         c_index:=c_index+1;
      IF BYTE_TO_INT(Data[i]) = 10 THEN
         r_index:=r_index+1;
         rowEnd:=TRUE;
         nCols:=c_index-1;
         c_index:=1;
   ELSE
      IF NOT(Data[i]=9) AND NOT(Data[i]=10) AND NOT(Data[i]=13) AND NOT(Data[i]=32) THEN
         accString := CONCAT(accString,WORD_AS_STRING(Data[i],0));
   i:=i+1;
   IF i>BytesRead THEN
      IF r_index=1 THEN
         nRows:=1;
      ELSE
         nRows:=r_index-1;
      IF nRows=1 THEN
         nCols:=c_index-1;
      RETURN;
END_WHILE
Please, since i'm relatively new to Codesys, try to answer in a complete manner. Examples are rare to find and documentation is not sufficient.
Thanks,
Luigi Ferrara.
PostPosted: Fri May 12, 2017 12:03 am
Hi.
Reading seems correct.
I had some similars troubles on raspberry. The problem was in files permisions.
Another problem that I had was in C300 from Lenze with rte. The problem was in file path. Use the same file path as you can see in your ide in plc part you can see your plc files.
PostPosted: Fri May 12, 2017 7:01 am
Hi!
First of all thanks very much.
Secondly, I don't think my problem is about permissions; in fact I am using windows with everything in run as admin. Maybe the second one you cited could be it.
So please, could you tell me more precisely what do you mean by files in the ide's plc? I'd like to have some more indications on the effective steps to do in Codesys.
Thanks,
Luigi Ferrara
PostPosted: Fri May 12, 2017 10:03 am
Hi.
In right tree go to device (plc). Wher the communications settings be.
Down to communications settings you can see files.
In files right window refresh. You can see tree folders. Go to your files folder and use the path ad you can see in location.
PostPosted: Fri May 12, 2017 10:04 am
Sorry, left tree devices
PostPosted: Fri May 12, 2017 10:23 am
Another thing. In some plcs you only can write on sdcard.
PostPosted: Fri May 12, 2017 3:39 pm
Thank you so much.
I've solved the problem using your tip and enabling all the permissions of the folder; running Codesys and RTE as ADMIN can be helpful.
Thanks again.
Users browsing this forum: A. Akkerman and 2 guests
