It is currently Fri Jul 28, 2017 4:01 pm
PostPosted: Fri May 05, 2017 7:23 am
Hi Everyone
I'm currently working on a project with a lot a data to send to a TouchScreen and as I'd like to optimize the communication speed, I have to use array
But for example, I build an array with all the data for my motor so I obtain
Motor1 array[1..10] of word;
So if in my program I do:
LD word1
ST motor1[1]
So I'd like if there is a way to give to this motor1 a name or a comment, so if I use my mouse on it, I could see the comment
Many thanks in advance for your help :)
PostPosted: Fri May 05, 2017 6:51 pm
Solution 1 (I recommend):
  • Have your speaking variables and structures as you need.
  • Have a HmiData array of WORDs
  • Create a PRG that is called every PLC scan with the name like "MapHmiData"
  • Explicitely map speaking variables to HmiData array (read only variables)
  • Explicetly map HmiData array entries to speaking variables (user write variables)
Advantages:
  • You get to use your speaking variables
  • You control scaling exactly as you need (i.e from REAL to WORD)
  • You can see exactly what variable goes to which array entry - no math, no counting in your head, etc.
Disadvantages:
  • Uses twice as much variable space (I've never run out of RAM space on a CoDeSys platform)
  • Manually code each assignment (but I prefer to see the explicit list 3 years from now when I forget what was being sent)
  • Takes CPU time (copying data into arrays of 100 or 200 WORDs does not take much processing power anymore - I've never had to optimize this until now over 11 years!)
Code Example:
PROGRAM MapHmiData
//copy drive1 data
GVL_APP.HmiData[0] := INT_TO_WORD(GVL_APP.Drive1.ControlWord);
GVL_APP.HmiData[1] := INT_TO_WORD(GVL_APP.Drive1.StatusWord);
GVL_APP.HmiData[2] := REAL_TO_WORD(GVL_APP.Drive1.Temperature * 10); //0.1 deg C resolution
GVL_APP.HmiData[3] := INT_TO_WORD(GVL_APP.Drive1.ActualCurrent);
GVL_APP.HmiData[4] := DWORD_TO_WORD(SHR(GVL_APP.Drive1.HourCounter,16)); //high word
GVL_APP.HmiData[5] := DWORD_TO_WORD(GVL_APP.Drive1.HourCounter); //low word
//copy drive2 data
GVL_APP.HmiData[6]  := INT_TO_WORD(GVL_APP.Drive2.ControlWord);
GVL_APP.HmiData[7]  := INT_TO_WORD(GVL_APP.Drive2.StatusWord);
GVL_APP.HmiData[8]  := REAL_TO_WORD(GVL_APP.Drive2.Temperature * 10); //0.1 deg resolution
GVL_APP.HmiData[9]  := INT_TO_WORD(GVL_APP.Drive2.ActualCurrent);
GVL_APP.HmiData[10] := DWORD_TO_WORD(SHR(GVL_APP.Drive2.HourCounter,16)); //high word
GVL_APP.HmiData[11] := DWORD_TO_WORD(GVL_APP.Drive2.HourCounter); //low word
//copy user data to controller
GVL_APP.UserCtrl.AutoRun     := WORD_TO_BOOL(GVL_APP.HmiData[20]);
GVL_APP.UserCtrl.CmdSpeed    := WORD_TO_INT(GVL_APP.HmiData[21]);
GVL_APP.UserCtrl.CyclesToRun := GVL_APP.HmiData[22];
Solution 2 (old school PLC programmer trick):
  • Define HmiData array at a specific memory location (AT %MW0)
  • Define your speaking variables at specific memory locations so they overlap with HmiData
Advantages:
  • Doesn't "waste" RAM by having two WORDS for same data
  • Doesn't use extra CPU time
Disadvantages:
  • Much work up front to align the memory locations
  • Cannot scale anything - what's in the memory location is how it will be.
PostPosted: Thu Jun 01, 2017 5:15 am
@scott_cunningham,
You could definitely scale using:
HmiData AT %IW101: ARRAY[1..10] OF WORD;
This attaches array to memory : [%IW101, %IW102, %IW103, ...%IW110]
Bad thing is all items must be of same data type.
PostPosted: Fri Jun 02, 2017 9:02 am
If you are using CoDeSys v3 which is assumed since this is posted in v3 section you could also use a reference to achieve this functionality. Reference is similar to a pointer but once you assign the reference you can use the variable just like any other variable.
   arWord: ARRAY[0..10] OF WORD;
   rMyWord: REFERENCE TO WORD;
rMyWord REF= arWord[0];
rMyWord:=777;  //arWord[0] will equal 777
You could also use pointers but you need to deference the pointer with the ^ operand each time to use the value.
   pMyWord1: POINTER TO WORD;
pMyWord1:=ADR(arWord[1]);
pMyWord1^:=777;  //arWord[1] will equal 777
The Original SoMachine Ninja
PostPosted: Fri Jun 02, 2017 5:56 pm
I've been using references a lot lately - they are great when you don't need scaling or conversion. I would recommend to add an initializer to references when they are defined to at least avoid crashes (unreferenced reference written to usually writes into a really bad space).
   SafeRef : WORD;
   MyRef1 : REFERENCE TO WORD := SafeRef;
You can also use
__IsValidRef()
to check - I will do that on FBs that have a state machine and I just define an init step.
Of course, when there is scaling or conversion, I use my "solution 1"...
PostPosted: Sat Jun 03, 2017 12:24 am
Not sure what you mean by scaling but if you mean casting then there is trick that you can use by the combination of pointers and references to make it work. See below an example how to cast a part of a word array to a REAL reference. Just keep note of the data type size when using pointer and not to exceed the array bounds.
   pMyREAL: POINTER TO REAL;
   rMyREAL: REFERENCE TO REAL;
pMyREAL:=ADR(arWord[1]);
rMyREAL REF= pMyREAL^;
rMyReal:=777.777; // arWord[1] and arWord[2] would hold real value of 777.777
PostPosted: Sat Jun 03, 2017 12:40 am
nothinrandom wrote:
@scott_cunningham,
Also if you mean casting the above is not true you would just define a second variable to cast it. All the example below would overlapp on memory thus automatically casting it
myByte  AT %MB0   : BYTE; //Byte Type
mySINT  AT %MB0   : SINT;
myUSINT AT %MB0   : USINT;
myByteArary AT %MB0 : ARRAY[0..10] OF BYTE;
myWORD  AT %MW0   : WORD; //16 bit types
myINT   AT %MW0   : INT;
myUINT  AT %MW0   : UINT;
myWordArary AT %MW0 : ARRAY[0..10] OF WORD;
myDWORD AT %MD0   : DWORD; //32bit Types
myDINT  AT %MD0   : DINT;
myUDINT AT %MD0   : UDINT;
myReal  AT %MD0   : REAL;
myDwordArray AT %MD0 : ARRAY[0..10] OF DWORD;
PostPosted: Sat Jun 03, 2017 7:16 pm
I don't mean casting. Many times, data is a WORD but has a scaling. For example, temperature may have a resolution of 0.1 degrees on a device but may only use a WORD to store it. In that case, a raw value of 123 means 12.3 degrees. If I don't care about the fraction, I only want 12. Or a better example is a servo drive that has a speed resolution of 0.125 rpm (+/- 4000 rpm is +/- 32000 raw data). This is held in a WORD register in the servo. There is no reason in most cases to display 0.125 rom resolution - much easier to just adjust the raw to be +/- 1 rpm before sending it. In this case, a second variable and "scaling" is the solution.
I just avoid at memory definitions - it obfuscates what's happening and requires someone to dig deeper to understand your code. I prefer to be explicit in my conversions at least, that's my style
