It is currently Fri Jul 21, 2017 11:34 pm
PostPosted: Fri Apr 28, 2017 8:07 pm
I have created a class (FB with Methods and Properties).
I would like one the variables within this class to be another class (FB with Methods and Properties).
But when I try to use F2 to enter a specific method or property of the instance within the instance, I cannot find the instance within.
I would like to access the elements something like:
ourLargeSystem[3].mySubSystem.mySubInt := 4;
This doesn't seem to work. I get an error that 'mySubSystem' is not an input of largeSystem.
Here's some pseudo-code. What I am doing wrong.
Thanks for any ideas. I must be missing something.
JP
GlobalVariables
ourLargeSystems : ARRRAY[1..10] OF largeSystem;
END Global Variables
FB largeSystem
VAR
_myInt : INT;
_myReal : REAL;
mySubSystem : subSystem
END_VAR
etc... with Methods and Properties
FB subSystem
VAR
_mySubInt : INT;
END_VAR
etc. with Methods and Properties
PostPosted: Fri Apr 28, 2017 10:58 pm
Your problem is scope of variables. Items defined as VARs of FBs are not available outside of the FB.
PostPosted: Fri Apr 28, 2017 11:46 pm
If you want to acces variables outside fb you habe to declare its as var_input.
But is a best practice to acces its via methotds (get set).
PostPosted: Sat Apr 29, 2017 4:43 pm
For true OOP you should be able to make the new fb with the extends or implements setting and then also use the super command too see the following as a good example. https://infosys.beckhoff.com/english.ph ... 9.html&id=
Sent from my SM-N9005 using Tapatalk
PostPosted: Wed May 10, 2017 9:55 pm
Thank you. That was the issue. I plan to use the methods for the member instances, but I could not "see" the member methods and properties until I moved the variable to VAR_INPUT.
Thanks.
jcp :D
PostPosted: Fri May 12, 2017 3:27 pm
You can also define the object as a VAR in your function block and then create a property for your function block that returns a reference to the object. Only create the get - delete the set. You can then have access to the internal object's methods and properties.
PostPosted: Wed Jun 07, 2017 6:34 pm
Here is a screen shot of your solution using a property and REFERENCE TO. You have access to all of subsystem's methods and properties. You do not have access to subsystem's internal VARs like mySubInt (the only debugger does, however). I used the property CurrentCount for that. (You could have a Set function for CurrentCount, and then you basically have access to your internal var).
