It is currently Fri Jul 21, 2017 11:36 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Apr 26, 2017 1:26 pm
After upgrade the development to V3.5.10.30 i take error when compare my costum data type:
[ERROR] CODESYS_V136_S351030: ACT_Fan_SETUP_CHECK [Device: PLC Logic: Application: RECIPES_Handle](Line 4, Column 1): C0066: Cannot compare type 'FanIOSetType' with type 'FanIOSetType'
If i compare the data type variables one by one works but not when compare direct the data type.
Any help?
PostPosted: Thu Apr 27, 2017 5:09 am
sounds like an accidentally shown precompile error -
Could you download the Project if you ignore this to the plc and this does work?
PostPosted: Tue May 02, 2017 9:13 pm
PostPosted: Wed May 03, 2017 4:43 am
then you need to give us the code snipet or project where it does occure.
PostPosted: Wed May 03, 2017 6:48 pm
PrjTest.zip
PostPosted: Wed May 10, 2017 5:15 pm
Any news?
You think is better we stay with Development 3.5.9.50 until fount any solution?
PostPosted: Thu May 11, 2017 5:14 am
give me some time sorry, the workaround is for sure to switch back only the compiler version to 3.5SP9x
and stay in current CODESYS version, but let us investigate the reason for this.
PostPosted: Thu May 11, 2017 12:59 pm
this is an error in the older Versions 3.5.8.0 and3.5.9.0 do not Report an compile error even they should do:
Reason:
CDS-29747: After thorough investigation we decided not to implement this feature:
a typical structure contains gaps due to alignment reasons, those gaps are not initialized and do not have a predefined value and should not have a predefined value. Therefore it is not possible to compare structures with a memcmp-function that does not know the internal structure of a structure.
The programmer write compare functions for those structures were the compare is needed.
PostPosted: Thu May 11, 2017 11:29 pm
That is very bad.
Did you understand how much work we need to do if we want our customers to stay updated for all our projects?
