Codesys 3 on Siemens IOT2040?
PJE
2017-04-12
2018-03-13
1 2 > >> (Page 1 of 2)
  • PJE - 2017-04-12
    Has anyone looked at implementing Codesys on the Siemens IOT2040 device?
    I would think it would make an ideal target - open, capable, UL approved, 24V powered...
    Zitat:
    SIMATIC IOT2040 from the SIMATIC IOT2000 product series at a glance
    Energy-saving Intel Quark processor and numerous interfaces: (+Secure Boot), , , 2 x RS232/485 interfaces, battery-backed RTC
    Support
    Can be easily expanded with und miniPCIe cards
    Various options for programming in high-level languages
    Compact design and DIN rail mounting
    Proven SIMATIC quality offers great ruggedness, reliability and longevity
    http://w3.siemens.com/mcms/pc-based-automation/en/industrial-iot/pages/default.aspx
    You could easily make custom Arduino shields to add functionality as needed.
    Regards,
    Peter
  • RolandWagner
    RolandWagner - 2017-04-13
    a SoftPLC for the IoT2000 series is already in the development. The first release is scheduled for June 2017 (CODESYS V3.5 Servicepack 11). A preview was visible on the Embedded World Show in March and the CODESYS Users Conferences. It was maybe for the very first time that a Siemens device was handling EtherCAT I/Os
    Stay tuned - the SoftPLC will be offered in the CODESYS Store quite soon...
  • PJE - 2017-04-14
    Roland Wagner hat geschrieben:
    Excellent News!
    I look forward to testing it when available.
    Will it support Web Visualization?
    PJE
  • RolandWagner
    RolandWagner - 2017-04-18
    I does not support CODESYS WebVisu in my preliminary Version, but it is very likely included in the release. I am not sure whether the colleagues will manage to integrate all requested features within the first "shot".
    Anyway: We are looking forward to having that SoftPLC, too
  • PJE - 2017-07-21
    Any update on the availability. I finally managed to get my hands on one...
    Sent from my Nexus 7 using Tapatalk
  • josepmariarams - 2017-07-28
    Hi all.
    Is this softplc hard realtime?
    How is maxjitter?
    eschwellinger - 2017-07-31
    Hi Josep,
    if you would apply a rt_preempt patched Linux kernel, this would be possible without modification of the plc runtime to have realtime capabilities,
    @PJE Webvisu will be in on 3.5SP11Patch1 release.
  • josepmariarams - 2017-08-06
    Thanks Edwin.
    I supose that thap patch makes the kernel hard real time(+-7us max jitter), not like raspi patch which has +- 100 us.
  • PJE - 2017-08-10
    I managed to install 3.5.11 on my IOT2040 and have a simple program running.... Thanks.
    I have a few questions:
    1. Any chance of a IOT2000 section in the forum like the BeagleBone and Raspberry PI? It would be nice to keep all the information together.
    2. Any information on access to Siemens I/O shield, as mentioned above by banzai35.
    3. Hardware implementations for Storage, Serial, Ethernet (fieldbusses). Can I have access to a folder on the MicroSD card or a USB memory device?
    4. How are persistent variables handled?
    5. When will Patch 1 be available for Webvisu?
    6. Any information on installing the real-time (rt_preempt) kernel as mentioned above? I use Codesys to hide all the complex stuff underneath ;0)
    It would be nice to put together a set of simple example programs to highlight the use of the units integrated functions.
    Regards,
    PJE
    eschwellinger - 2017-08-10
    Hi PJE
      hm.. let me check
      yes good chance to get it will take some time
      yes should already work
      not implemented at the moment - where is it located physical address etc ?
      next week I guess
      almost the same process like with other Linux Systems.. - guess for IOT there is a Yocto build environment available? Isn't it?
  • PJE - 2017-08-11
    Thanks. I'll see what I can do on examples and the real time kernel, and post what I can.
  • FAPeter - 2017-10-26
    Hi Edwin & Roland Wagner Codesys expert,
    I am also Crazy used codesys and IOT2040 partner,
    but i only can do codesys on windows based and did not know how to install codesysy runtime in IOT2000 image (Yocto linux ).
    Could you let me know how to build up codesys runtime in IOT 2040 ?
    BR,
    Peter
    eschwellinger - 2017-10-26
    where exactly do you stuck?
    Use the Update IOT Command to do it:
    IMG: InstallIOT.jpg
  • FAPeter - 2017-10-27
    Hi Edwin,
    in fact i not know how to start use codesys in IOT2000.
    i usually only use codesys windows base , and ony use Putty have command line for IOT2040 node-red application ,
    so i like to know how to first step up codesys in iot2040 ,
    does have any document let me know how to quick start in to codesy based on iot2000 series for test sample application?
    and what kind tools i need prepare?
    BR,
    Peter
  • banzai35 - 2017-11-06
    Hi all,
    When access to Siemens I/O shield for IoT 2000 will be ready?
    banzai35
    eschwellinger - 2017-11-09
    at the moment I have no date for this.
  • FAPeter - 2017-11-09
    Hi Edwin,
    It not look like same Putty software tool,
    1.) Where i can get your photo show IOT2000 download software tool ?
    2.) Does your software is download what's software to IOT2000? is for codesys runtime setup to IOT2000?
    3.) Have any operation manual for me to enable start use codesys in iot2000
    Many thanks!
    BR,
    Peter
    eschwellinger - 2017-11-10
    Hi Peter,
    this is the webvisu example from Raspberry Pi package (the project is in the Forum post embedded too)
    Basically the steps are the same if you use IOT like using Raspberry PI
    1. install the package for IOT by clicking on the cart in CODESYS - search IOT , install
    2. restart CODESYS
    3. use the roject from the post (open it in CODESYS)
    4. deploy the IOT runtime by - Tools -> Update IOT2000 command (scan your IOT and install the runtime)
    5. Now you could scan the IOT in the CODESYS Commuciation go online and work with it
  • GBO02 - 2017-11-18
    Hello
    i have got a raspberry PI3 and a SIEMENS IOT SIEMENS
    i have make a small program to test it.
    I have program it in SFC to test.
    I use for my application :
    - WAGO 750 Ethernet IP I/O (1x16 inputs 24VDC + 1x16 outputs 24VDC + 1x2 analog Output +/-10VDC)
    - Raspberry PI3 + Raspi TouchScrenn 7''
    when i change Raspi to IOT it working exactly same (except for the screen no possibility to use raspi screen on)
    Hello
    I have use this website to create image
    https://sourceforge.net/p/iot2000-debia ... n%20image/
    you can find exemple on youtube
  • stricky - 2018-01-12
    is it possible to use the RS485 on the IOT ?
    Chris
  • f.fallon - 2018-02-22
    Hi There, Any update on this? I have an application to which I need to read analog inputs, it would be nice to be able to program it using the codesys softPLC for the IOT2040.
