It is currently Thu Jun 27, 2019 1:40 pm
 Post subject: Write file in unicode
PostPosted: Tue Mar 28, 2017 10:15 am
Hi all,
I'm trying to write a file with the SysFile library. How can I write unicode characters? It seems the library writes only in ANSI.
Thank you,
Regards.
Massimo
PostPosted: Sun Dec 09, 2018 4:05 pm
Massimo.Milluzzo wrote:
Hi all,
Thank you,
Regards.
Massimo
Hi, I'm intereste in this too. I've made a lot research on it and no CoDeSys based device were able to save file in unicode. Only ANSI... But I've used Festo PLC, which uses Linux RT and the files saved on SD card by SysLibFile were in UTF-8...
PostPosted: Mon Dec 10, 2018 6:05 am
There is no problem, just use WSTRING type and byte ordermark.
Library writes not ANSI or Unicode or something else, library just writes data.
Make CODESYS great again
PostPosted: Mon Dec 10, 2018 9:04 am
Thanks a lot for this solution!
PostPosted: Tue Jun 25, 2019 11:45 am
Well, that was for writing. But what would I do if i want to read unicode from the file?
If I do
SysFileRead(hFile:=FileHandle, pbyBuffer:=ADR(wsData), 2 * TO_DWORD(Standard64.WLEN(wsData)), pResult:=pResult);
my wsData => WSTRING(255) gets totally wrong numbers. ex. for the letter 'h'(hex 68) i get something like 20 thousand which can't be converted back to the letter 'h' from ASCII ... what am I doing wrong??
PostPosted: Tue Jun 25, 2019 2:49 pm
Which exact value? ("something like 20 thousand...")
PostPosted: Tue Jun 25, 2019 3:12 pm
Well I already found the problem but the exact value was 26721(WORD). I found out that it was utf-8 so it was reading it 1 byte at a time but into a WSTRING of which every char is a 16bit WORD and it also was not utf-8, the encoding was ISO 8859-1 / latin1, which means all the other chars than the ascii (0-127) are not encoded correctly. 26721 in hex is 6861 which corresponds to the letters h(68) a(61).
So my problem still stands, I can't display those characters. 0-127 works just fine.
PostPosted: Tue Jun 25, 2019 3:20 pm
So you have file with UTF8 charset?
Try to use StringUtils library, function ConvertUTF8ToUTF16.
PostPosted: Wed Jun 26, 2019 7:58 am
I didn't know that such a thing existed.
I'm going to try it later.
Thanks.
