It is currently Tue Sep 17, 2019 11:22 am
 Post subject: Udp and multicast
PostPosted: Tue Mar 21, 2017 5:46 pm
Hi all,
I'm trying to send data by UDP sockets but I get always error with multicast IP addresses (i.e. 239.2.3.4).
I'm able to send data to a "normal" IP address like 192.168.10.25 but not multicast or broadcast. I don't know what I wrong. I am new in Codesys v3.
declarations:
IP_Addr:   NBS.IP_ADDR := (sAddr := '192.168.10.25');
IP_Multicast:   NBS.IP_ADDR := (sAddr := '239.2.3.4');
IP_Port:      UINT := 2053;
UdpPeer:      nbs.UDP_Peer;
UdpSend:      nbs.UDP_Send;
by using;
UdpPeer(
   xEnable   := TRUE,
   ipAddr   := IP_Multicast,
   uiPort   := IP_Port   );
UdpPeer returns "NO_ERROR" but UdpSend returns "UDP_SEND_ERROR"
Instead, by using:
UdpPeer(
   xEnable   := TRUE,
   (*ipAddr   := IP_Addr,*)
        ipMultiCast   := IP_Multicast,
UdpPeer status returns "WRONG_PARAMETER" .
Same results by setting or ipAddr = '255.255.255.255' or '0.0.0.0' (see library doc)
Has someone an idea ?
Many thanks in advance
 Post subject: Re: Udp and multicast
PostPosted: Wed Mar 22, 2017 6:20 pm
I solved (partially?) the issue by differentiating the ip address and port of Peer and sender.
PeerIpAddr.sAddr   := '255.255.255.255'; (* or 127.0.0.1 or other non multicast IP address *)
PeerIpPort         := 49999; (* or other port not used *)
SenderIpAddr.sAddr := '239.2.3.4';
SenderIpPort      := 2053;
RTR:   R_Trig;
Send:    BOOL;
DataTx:   STRING:='Hello Multicast !!';
UdpPeer(xEnable := TRUE, ipAddr := PeerIpAddr, uiPort := PeerIpPort);
IF UdpPeer.xError THEN
   UdpPeer(xEnable := FALSE);
   Send         := FALSE;
RTR_Send(CLK:=OneShotCmd); (* check rise of send command *)
IF RTR_Send.Q AND UdpPeer.xActive AND NOT UdpPeer.xError THEN
   Send   := TRUE;
(* UPD sender *)
UdpSend(
   xExecute   := Send,
   ipAddr   := SenderIpAddr,
   uiPort   := SenderIpPort,
   hPeer   := UdpPeer.hPeer,
   szSize   := SIZEOF(DataTx),
   pData   := ADR(DataTx),
   udiTimeOut   := 1000000, (* usec *)
IF UdpSend.xDone THEN
   Send   := FALSE;
IF UdpSend.xError THEN
   Send   := FALSE;
   UdpSend(xExecute:=FALSE);
Problem: it is the right way ? Is there any guidelines for using these libraries ?
PostPosted: Fri Mar 31, 2017 2:22 pm
OK I've fixex the data transmission. You Don't need to separate IPaddr. and IPport of Peer and Sender. You only need to setup in the right way the Gateway of the device.
PostPosted: Fri Mar 31, 2017 2:24 pm
The question is now:
how can i read the UDP multicast/broadcast data sent from other devices ?
Is it possible in codesysV3 ?
PostPosted: Tue Jan 16, 2018 8:06 am
Dear Edwin, can you help with simple example UDP Multicast? (Sender/Receiver)
Another topic with similar situation:
https://forum-de.codesys.com/viewtopic. ... 324#p17085
It would be nice to get simple example (for example, for Raspberry Pi) to undestand how it works in CDS V3.
Make CODESYS great again
