Cfc methos
2017-03-02
2017-03-03
  • josepmariarams - 2017-03-02
    Dears.
    It is possible to call a fb.method feom an cfc editor?
  • Anonymous - 2017-03-02
    Yes. Calling it can be a bit tricky.
    My CoDeSys version underneath my OEM software: 3.5.6.66
    IMG: screenshot.png
    Thanks a lot Scott.
    I have test the first solution and it has not work. I suppose it is a version problem.
    But the question is: how you have disvovered the second solution.
  • josepmariarams - 2017-03-03
    Scott.
    I have test it but I have problems with inherited methods:
    To use inherited methods with the first method it is necessary to overload the method in the inherited class and call the method using this^. After that it is possible to erase the inherited method and the this^. In this case the method doesn't works if it has not outputs, and is not possible to update pins.
    The better solution is using the second option that Scott has said:
    IMG: Captura de 2017
