Hello
Rt 3.5.7.10
I can use the Modbus RTU library without problem to talk to Modbus slaves.
I have now added the serial communication library to use another serial port (not modbus).
When I open this port, the modbus dies after 1 minute (error 162, CRC error)
If I don't open the new port then the modbus comms is happy for 'ever'.
Any suggestions?
Paul
Paul is running Codesys on a Beijer Electronics TxB SoftControl master, runtime v3.5.7.10.
I am able to reproduce the error in my office. I get Modbus going, all is fine, then I open a completely different port using the COM.Open block. This causes the Modbus to fail after a certain time, always around 55s.
However, if I try using a PC with Codesys RTE v3.5.9.40 or a Beijer Electronics X2 Control, runtime v3.5.9.50, then everything works fine.
So... the error seems to be related to either Codesys SP7 or the TxB SoftControl itself.
Request to Codesys:
Please check JIRA logs for anything related to this between SP7 Patch 1 and SP9 Patch 4 and Beijer Electronics will continue investigating how ports are handled by the old TxB master.
Kim Hansen
Beijer Electronics Products AB
Hello
Rt 3.5.7.10
Any suggestions?
Paul
Further information to Paul/Codesys:
Request to Codesys:
Kim Hansen
