Hello!
I have a question about the compiling prosess, more spesific generating the hex file. in a Bosch Rexroth Bodas Design application
When I activate the rebuild function the program starting the compiling prosess and generates the HEX file.
But for some reason it becomes uncomplete and gets a "RUN HEX" ending at the file name....!
When I try to flash the file into the device it goes fine without errors, but as I mention earlier it misses som parameters..!
As you probably understand I am a newbe to this and I hope someone could give me some advice what is wrong here?
Hello!
Please take a look at the enclosed doc.
Thanks in advance
HEX generated.pdf [121.6 KiB]
