Hlelo,
I am calling an OK/Cancel dialog from a Visualization. Is there any way to know on the Visualization that a certain button was pressed on the Dialog?
Something like:
(OnDialogClosed method:)
IF DialogResult = OK THEN
// perform action A
ELSE
// perform action B
I resume this old post to do a question about the dialogs.
Is it possible to understand if a dialog is open or not?
I want to associate a boolean variable TRUE if the dialog is open, FALSE if closed.
Thank you
Hlelo,
Something like:
// perform action A
ELSE
// perform action B
Does nobody know the answer?
Is it not possible at all?
I thought that was the reason why Dialogs existed: to get a Yes / No (or other) response from a user and make use of the result on a Visualization...
Hello
You can find a free example in the CODESYS Store, called "Visalization Dialog Box"
Originally created by: Massimo.Milluzzo
Thank you
