I've started a new project and just added an ethernet adapter and then an ethernet/ip scanner to the tree. I already get errors that im unable to resolve.
-There is no resolution for the placeholder IoDrvEtherNetIPAdapter
-Library CmpVisuHandler, 3.5.5.0 (System) has not been added to the Library Manager, or no valid license could be found
-Library SysFile, 3.5.5.0 (System) has not been added to the Library Manager, or no valid license could be found
How can i fix theses?
I'm also always facing with the same issue whenever I open an old project. It totally drives me crazy...
Whatever I do with placeholders or anything just not works (pic attached). If I click on the try to resolve button I just get a message that it can't. If I open a new project and copy the visu stuff of course it works fine... but how could I solve the problem? Where the hell can I look for the solution?
GergΓΆ
What is your IDE? Doesnt look like plain Codesys...
However, you have to add the libraries mentioned from the compiler to your project. Open the library manager, go for add library and go to advanced. There you can put in the name of the library and you should be able to find it.
In your case CmpVisuHandler and SysFile.
Hello people,
GergΓΆ
