https://forum.codesys.com/
Ethernet IP Address - Route to tag?
https://forum.codesys.com/viewtopic.php?f=11&t=7159
Page 1 of 1
Author:  jamesbuniak [ Tue Aug 23, 2016 5:59 pm ]
Post subject:  Ethernet IP Address - Route to tag?
I am trying to use an Ethernet field bus device communicating as a Modbus Master/Slave configuration and would like the end user to be able to change the IP address of the slave device.
This device will be going into locations where non programmers will be entering in the IP address.
Does anyone know if this is possible?
Field bus
Vendor: 3S - Smart Software Solutions GmbH
Categories: Ethernet Adapter, Ethernet Adapter, Ethernet Adapter
Type: 110
Version: 3.5.7.0
Order Number: -
Description: Ethernet Link.
Modbus Master
Name: Modbus TCP Master
Categories: Modbus TCP Master
Type: 88
Version: 3.5.9.0
Order Number: -
Description: A device that works as a Modbus Master on Ethernet.
Modbus Slave
Name: Modbus TCP Slave
Categories: Modbus TCP Slave
Type: 89
Version: 3.5.7.0
Order Number: -
Description: A generic Modbus device that is configured as Slave for a Modbus TCP Master.
Configuration version: 3.5.3.0
Thank you,
https://www.phpbb.com/
