It is currently Tue Feb 18, 2020 7:30 am
PostPosted: Fri Aug 05, 2016 5:33 pm
Dear community,
i'm using VAR_GLOBAL CONSTANTS in an Library to define upper and lowerbound of an array. All VAR_GLOBAL CONSTANTS, have an predefined init value.
Now i want to predefine the init value from my Project, where i'm using the Library. I tried to override the VAR_GLOBAL CONSTANTS in the Library from the project, but it doesn't work.
Is there any solution or work arround?
Thank you in advance!
PostPosted: Fri Aug 05, 2016 8:30 pm
You may find this thread of some use
viewtopic.php?f=11&t=6971
Rick
PostPosted: Fri Aug 05, 2016 10:06 pm
For libraries, add a library "Parameter list" object (screenshot below). This will allow you to define a constant that can be changed when the library is used in a project. The online help should give more information - topic parameter list and then sub-subject GVL.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Sat Aug 06, 2016 8:59 am
Hello scott,
thank you for the fast reply.
I added an Parameter list "Param_XY" in the library:
VAR_GLOBAL CONSTANT
   // Array Param
   gc_UpBound : INT := 10;
   gc_Length     : INT := 100;
   // Timeout Param
   gc_TimeOut    :TIME := T#10S;
END_VAR
FB in Library with Array
VAR_INPUT
   arrTest : ARRAY [0..gc_UpBound] OF STRING(gc_Length);
END_VAR
PRG in Project:
VAR
   arrXXX: ARRAY [0..gc_UpBound] OF STRING(gc_Length);
END_VAR
In the PRG i fill the arrXXX (within the range) and then i call the FB in the library and use the declared arrXXX as Input. This works all fine.
But I can't change the CONSTANT Vars in the Paramter List "Param_XY".
I tried to add an GVL in the Project:
VAR_GLOBAL CONSTANT
   // Array Param
   {attribute 'const_replaced'}
   gc_UpBound : INT := 20;
   gc_Length     : INT := 200;
   // Timeout Param
   gc_TimeOut    :TIME := T#50S;
END_VAR
but it doesnt override the paramters in the library and it allways use the parameters from the lib.
I can't find anything in the help file about that topic expect the attribute 'const_replaced'.
What I'm doing wrong?
Thank you in advance.
PostPosted: Sun Aug 07, 2016 2:22 pm
Everything was good until your last step. Don't define the variable again in your main project. Instead, from your project, open the library object (like you are going to add a library to your project) and then highlight your library and look at the available objects - you will see you "parameters" and you can insert the value you want.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Mon Aug 08, 2016 10:25 am
Scott - thank you so much for your support!
This was exactly the right thing what I was looking for.
Have a nice day!
cheers
PostPosted: Fri Jan 03, 2020 12:05 am
Hi guys,
I'm doing a library where i need to be able to change the library constants from the project where the library is used. I simply can not find anywhere where it is possible to add this "Parameter list". Also I find no reference in the help to such a parameter list? Any surgestions on how to achieve changing library constants from project (In 2.3 you simply declared a variable with the same name in the project)
It seems that "Parameter list" is removed in 3.5.15.x as well as support for libraries pre. version 3 (2.3 libraries)
