i'm using VAR_GLOBAL CONSTANTS in an Library to define upper and lowerbound of an array. All VAR_GLOBAL CONSTANTS, have an predefined init value.
Now i want to predefine the init value from my Project, where i'm using the Library. I tried to override the VAR_GLOBAL CONSTANTS in the Library from the project, but it doesn't work.
Is there any solution or work arround?
Thank you in advance!
2016-08-05
For libraries, add a library "Parameter list" object (screenshot below). This will allow you to define a constant that can be changed when the library is used in a project. The online help should give more information - topic parameter list and then sub-subject GVL.
2016-08-06
Originally created by: KevinR
Hello scott,
thank you for the fast reply.
I added an Parameter list "Param_XY" in the library:
VAR_GLOBALCONSTANT  //ArrayParam  gc_UpBound:INT:=10;  gc_Length   :INT:=100;    //TimeoutParam  gc_TimeOut  :TIME:=T#10S;END_VAR
FB in Library with Array
 VAR_INPUT  arrTest:ARRAY[0..gc_UpBound]OFSTRING(gc_Length);END_VAR
PRG in Project:
VARÂ Â arrXXX:ARRAY[0..gc_UpBound]OFSTRING(gc_Length);END_VAR
In the PRG i fill the arrXXX (within the range) and then i call the FB in the library and use the declared arrXXX as Input. This works all fine.
But I can't change the CONSTANT Vars in the Paramter List "Param_XY".
I tried to add an GVL in the Project:
VAR_GLOBALCONSTANT  //ArrayParam  {attribute'const_replaced'}  gc_UpBound:INT:=20;  {attribute'const_replaced'}  gc_Length   :INT:=200;    //TimeoutParam  {attribute'const_replaced'}  gc_TimeOut  :TIME:=T#50S;END_VAR
but it doesnt override the paramters in the library and it allways use the parameters from the lib.
I can't find anything in the help file about that topic expect the attribute 'const_replaced'.
What I'm doing wrong?
Thank you in advance.
2016-08-07
Everything was good until your last step. Don't define the variable again in your main project. Instead, from your project, open the library object (like you are going to add a library to your project) and then highlight your library and look at the available objects - you will see you "parameters" and you can insert the value you want.
2016-08-08
Scott - thank you so much for your support!
This was exactly the right thing what I was looking for.
Have a nice day!
cheers
scott_cunningham hat geschrieben:
Hi guys,
I'm doing a library where i need to be able to change the library constants from the project where the library is used. I simply can not find anywhere where it is possible to add this "Parameter list". Also I find no reference in the help to such a parameter list? Any surgestions on how to achieve changing library constants from project (In 2.3 you simply declared a variable with the same name in the project)
It seems that "Parameter list" is removed in 3.5.15.x as well as support for libraries pre. version 3 (2.3 libraries)
Hello, I'm trying to do the same thing and I don't understand how to do.
Into CODESYS HELP they spoke about ParameterList here : https://help.codesys.com/webapp/_cds_cmd_save_project_as;product=codesys;version=3.5.15.0 , in the chapter "Before saving a project as a library:"
"A parameter list is a special type of global variable list." yes, but how to get it ?
Dear community,
You may find this thread of some use
l viewtopic.php?f=11&t=6971 l
Hello scott,
PRG in Project:
Have a nice day!
cheers
Hi guys,
It is maybe a late answer but I faced the same issue and I found the location of the library parameter list as indicated in the photo
