I have to exchange data between a PLC program with Codesys V3.5 and a Windows application.
These 2 applications will run on the same computer. I have updloaded the shared memory package on the Codesys Store.
I am looking for an example or some explanations to use this tool in a simple project.
Thanks for your help
I have already installed the relevant shared memory package.
But I don't know how to use these package function in Codesys.
Have you found an example or how to use it?
I am also looking for an example or some explanations to use this tool in a simple project.
Thank you!!
2017-11-30
Originally created by: Viacheslav Mezentsev
Shared memory may works differently on the Windows system and the target device. Here below the working example on the Raspberry Pi 3 with C#. You need to describe the problem more accurately.
Hi, I have the same application needs as you.
Thank you!!
