Beckhoff EtherCat Serial Communication
2015-02-18
2020-01-23
  • yannickasselin1 - 2015-02-18
    Hi there,
    Is it possible to use some EtherCat serial Communication terminals like the Beckhoff EL6001, EL6002, EL6021, EL6022 right in CODESYS?
    I know how to use them in TwinCat with the function blocks provided from Beckhoff but I'm wondering how to use them in CODESYS V3.
    Can I use the Beckhoff function blocks in CODESYS? Or are there any other function blocks I can use?
    Does someone have a sample code?
    Thank you.
  • rotemse - 2018-05-14
    I also like to know the answer. I am using EL6021 (RS485).
    Can I use it with Codesys Modbus master?
    When I try, the Modbus master asks me for COM port...
    How can we do that?
  • rotemse - 2018-05-15
    anyone?
    eschwellinger - 2018-05-16
    no there are no drivers available to have them as serial device.
    The only way to use them is to use the process data in your application which is
    probably a huge effort.
  • perIpI - 2020-01-09
    Sorry for bumping an old thread!
    Is this still the case (no serial com-port driver available for Beckhoff EL602x-modules)??
    Im using Berghof EC1000 with Beckhoff-IO and will need RS485 to communicate. Berghof EC1000 has on-board RS232 but not RS485. Speaking with supplier about availability of EC-COM 01/02 module which should provide RS485, but unsure if they are available. Are there other alternatives?
  • i-campbell
    i-campbell - 2020-01-09
    An RS232 to RS485 converter will get you out of trouble.
    Here's an example from MOXA.
    https://www.iiotzone.com/tcc-100100i-series?c=3
    If you don't want to use 232 for whatever reason, you can go via ethernet as well. You just install the Linux driver, and the remote comport shows up as a tty. Also from MOXA.
    https://www.iiotzone.com/nport-5100-series
    I can't see any EL602x in the store or online help.
  • perIpI - 2020-01-10
    Thanks! Will try out a RS232/485 converter. Also got confirmed availability of Berghof EC-COM-02 unit with onboard RS485 (with some deliver time delay). Will update when tested.
  • teafiboss - 2020-01-23
    Hi all,
    I am a newcomer in the Codesys and EtherCAT world and I am absolutely amazed by the power and versatility of these systems.
    I have a Beckhoff EL6022 module (2 RS485 ports) and I would like to know if there is a way to communicate via Modbus RTU with PLCs or if it will be possible in the future.
    In my little development system I also have an EL6751 (CAN Master) and it works very well.
    I tried to insert the EL6022 in a test project but I did not understand how to use configurations such as Expert Process Data, Process Data, and so on.
    However, there are many other things that I didn't understand so I don't get angry
    Marcello
