It is currently Wed Oct 23, 2019 10:56 am
 Post subject: SQL for codesys 3.5
PostPosted: Fri Jun 27, 2014 11:44 am
I use CoDeSys 3.5 SP3 for panels Wachendorff with linux operating system
I need connecting to database LiteSQL using SQL by lines of code.
I see one example end library SQL4CODESYS downloaded from the store
Wachendorff with CoDeSys 3.5base is sufficient for running application?
thanks Luca
 Post subject: Re: SQL for codesys 3.5
PostPosted: Wed Jul 09, 2014 6:24 am
Hi Luca
The SQL4CODESYS library uses the SysSocket library for communicating over TCP/IP to the SQL4automation Connector service.
If your system supports that, it should be possible to use SQL4automation to connect to any database that supports ODBC.
Is there an ODBC driver for LiteSQL? Or did you mean SQLite?
Roger
PostPosted: Tue Oct 11, 2016 12:56 pm
I'm looking too about a SQL library for CodeSys. But I only want to manage a local database in a first time.
So, SQL4CODESYS can exchange with a database store into a local memory of my PLC or I need other library ?
Thomas.
PostPosted: Fri Oct 14, 2016 7:25 am
Hello Thom,
you can also use the library for MySQL (see store: http://store.codesys.com/mysql-library-sl.html.
The library doesn't need any 3rd-party software as ODBC-Drivers or other software, you can execute sql commands from your controller.
If you have permissions and an compatible operating system, then you can also install an MySQL Server directly on your controller.
Best Regards,
Kevin
Building & Process Automation with HVAC Library for CODESYS© - www.hvac-automation.com
PostPosted: Sun Mar 05, 2017 2:49 pm
free of use MySQL lib for Codesys V3
https://www.dropbox.com/s/zm32vdsdav67b ... chive?dl=0
free of use MySQL lib for Codesys V2
https://www.dropbox.com/s/9tsg8m4e34qfa ... T.zip?dl=0
And MSSQL lib same
https://www.dropbox.com/s/y9ib3jl3tvdcq ... 3.rar?dl=0
https://www.dropbox.com/s/7tl4kixx2v8j4 ... T.zip?dl=0
PostPosted: Thu Jul 11, 2019 4:02 pm
murdemon wrote:
Hello i try to use that lib on a win RTE 64 system i have some precompiled error, anybody to help me ?
Users browsing this forum: No registered users and 8 guests
