Showing custom dialog from PLC code
sjdebdaly
2014-01-17
2014-02-06
  • sjdebdaly - 2014-01-17
    Hi all,
    I've seen that it's possible to change the current visualisation via code, with or without a frame, but is it possible to display a dialog from code?
    IF expression THEN
    Β  Β ShowDialog();
    END_IF;
  • saullipton - 2014-02-06
    I would be interested in knowing the answer to this question as well. Does anybody have the knowledge? Do we have to add a visualization? The visu adds quite a bit of size to the application...
    Thanks,
    Saul Lipton
    Applications Engineer
    NUM USA
