It is currently Wed Oct 16, 2019 10:22 am
PostPosted: Wed Sep 11, 2013 9:26 pm
I have a function block that implements the IAlarmNotifier interface, I have it doing most of what I want, but I cannot get the alarm message. The key part of the execute method is below. Any ideas why GetMessage always returns a null string. I am successfully getting the name of the AlarmGroup and the AlarmClass it is just this interface function that is tripping me up.
    {attribute '''DOCU__COMMENT' := ' Executes the action.'}
    (* Executes the action.*)
    METHOD Execute
    VAR_INPUT
    (* The currently processed alarm state transition. This will be
    evaluated in order to determine, whether the action has to be
    executed or not*)
    eCurrTransition : AlarmStateTransition;
    (* The alarm, for which the action has to be performed*)
    itfAlarm : IAlarm;
    (* An optional pointer to a structure variable containing
    additional parameter*)
    pbyAdditionalData : POINTER TO BYTE;
    cbpMessage: AlarmManager.CharBufferPtr; (* for holding the AlarmMessage *)
    cbpMessage := itfAlarm.GetMessage(__SYSTEM.TYPE_CLASS.TYPE_STRING);
    StrConcatA(cbpMessage,ADR(sLastAlarm[0]),USINT_TO_INT(SIZEOF(sLastAlarm)));
PostPosted: Thu Sep 12, 2013 5:59 am
Hi David,
The message text is empty because no visualization occurs in the project.
background:
Without visualization, the text lists are not transferred to the control, and therefore the text can not be determined.
This is as designed, to fix that you Need to add a visu to your project.
PostPosted: Thu Sep 12, 2013 8:24 am
Thanks Edwin - that worked a treat. I would never have guessed that :D
Users browsing this forum: No registered users and 9 guests
