Unknown type:“CAA.HANDLE"
yue-qi-qi
2013-04-17
2013-04-19
  • yue-qi-qi - 2013-04-17
    I have add the library CAA File,3.5.0.0(CAA Technical Workgroup) to the Library Manager, but the system can not recognize ”CAA.HANDLE“.
    I then add the library of ”CAA Real Time Clock Extern“,and CAA TickUtil Extern,but it still does not work.
    Untile I add the library of CANBus,3.4.1.0.
    Who can tell me the reason?
    I got it; it should be ”file.CAA.HANDLE“。
    too much difference from the old version!
  • TimvH
    TimvH - 2013-04-17
    I hope you understand the reason behind it.
    With these improvements in the library/compiler you are always 100% sure you have the correct variable and not another from another library.
    Off course it is a change from 3.4, but better a change with improvements than no changes at all.
  • yue-qi-qi - 2013-04-19
    yes,you are right
