It is currently Tue Feb 25, 2020 11:28 pm
PostPosted: Tue Feb 19, 2013 1:22 pm
Hallo Forum,
gibt es eine Funktion/Bibliothek um den Steuerungsnamen aus CODESYSCONTROL.CFG auszulesen?
Oder muss ich das von Hand und mit SysFile selbst bewerkstelligen?
Does a function/library exist to read out the nodename-value from CODESYSCONTROL.CFG?
Or do I have to read manually with library 'SysFile'?
Mensch nimm dir Zeit und nicht das Leben
PostPosted: Fri Feb 22, 2013 12:41 pm
Good question. Please share your solution if you have found out how to do this.
You could use the CmpApp library to get information about the application, but as far as I have seen this doesn't give information about the device name.
PostPosted: Fri Feb 22, 2013 2:34 pm
my solution, quick and possibly "dirty" -> is there a better solution ?
e.g.
PROGRAM ReadOutSysInfos
   init: BOOL;
   strTemp: STRING(255);
   strBoardName: STRING(30);
   strBoardName2: STRING(30);
   wstrBoardName2: WSTRING(30);
   fileHandle:    SysTypes.RTS_IEC_HANDLE;                  // File handle number
   fileName:      STRING[63] := '/flashdisk/CodesysV3/CoDeSysControl.cfg';      // Path and file name
   rte:          RTS_IEC_RESULT;                  // Error code according runtime error list
   ptrToString: POINTER TO BYTE;
   ptrToString1: POINTER TO BYTE;
   ptrToString1a: POINTER TO STRING(255);
   strCmp1: STRING(12):= '[SysTarget]';
   readSize: UDINT := constantReadSize;
   bytesRead: UDINT := 0;
   udi :UDINT;
   readLog:      ARRAY [0..constantReadSize] OF BYTE;// Array to read old logs
   str_offset: INT;
   str_offset2: INT;
   iLen: INT;
   strComponent : STRING:='SysTarget';
   strKeyValue: STRING:='NodeName';
VAR CONSTANT
   constantReadSize:   UDINT:=4000;
IF init = FALSE THEN
   IF strBoardName = '' THEN
      fileHandle := SysFileOpen(fileName, AM_READ,  ADR(rte));   // Open original file
      IF (fileHandle = 16#FFFFFFFF) OR (fileHandle = 0) THEN
         strBoardName := 'invalid handle';
      ELSE
         strBoardName := 'not found';
         ptrToString := ADR(readLog);
         ptrToString1 := ADR(strCmp1);
         bytesRead := SysFileRead(fileHandle, ptrToString, readSize, ADR(rte));   // Read the original file
         FOR udi:=1 TO (bytesRead - 250) DO
            ptrToString1a := ptrToString;
            str_offset := Standard.FIND(ptrToString1a^, strCmp1);
            IF str_offset > 0 THEN
               ptrToString1a := ptrToString1a + str_offset;
               str_offset := Standard.FIND(ptrToString1a^, 'NodeName=') + 8;
               IF str_offset > 8 THEN
                  ptrToString1a := ptrToString1a + str_offset + 1;
                  ptrToString1 := ptrToString1a + Standard.FIND(ptrToString1a^, '$R') - 2;
                  ptrToString1^ := 0;
                  strBoardName := ptrToString1a^;
                  EXIT;
            ptrToString := ptrToString + 1;
         END_FOR
         rte := SysFileClose(fileHandle);            // Close original file
   init:= TRUE;
Users browsing this forum: No registered users and 10 guests
