Hi:
when using the logger , I encountered three problems,who can help me?
1, inside the file of CodeSysSP.cfg,under the component of CmpLog ,"Logger.0.Backend.0.classid = 0x00000104" What does it mean?(0x00000104 --#define ITFID_ISysFile )
2,How can I change the format of the log file?only .csv?
3,How can I determine the number of log in the file?
I don't think it is a good idea to change this file.
It is a file created by the OEM. If you make any incorrect changes, the runtime might not work anymore.
TimvH hat geschrieben:
thanks for your answer,
I saw the component of CmpLog is blocked in this file , if i no change this file ,although i can see the message , but i can‘t find the file in my root。
Hi:
