It is currently Mon Jan 20, 2020 9:19 pm
PostPosted: Tue Jul 10, 2012 2:11 pm
I am currently working on a TCP/IP implementation in CoDeSys V3, whereas the IEC61131-3 program has to be the server. For whatever reason, it is not possible to receive any data from the point of view of TCP client, even though a working connection could be established.
I am using the NetBaseServices.
Please refer to the following code:
---HEADER---
PROGRAM TCP_Client
VAR
   bFirst: BOOL := TRUE;
   My_Data: ARRAY[0..4] OF BYTE := [0,1,2,3,4];
   NBS_IP_Adress : NBS.IP_ADDR;
   TCPClient : NBS.TCP_Client;
   TCPClient_xDone : BOOL;
   TCPClient_xBusy : BOOL;
   TCPClient_eError : NBS.ERROR;
   TCPClient_xActive : BOOL;
   TCPClient_hConn : NBS.CAA.HANDLE;
   TCPServer : NBS.TCP_Server;
   TCPServer_xDone : BOOL;
   TCPServer_xBusy : BOOL;
   TCPServer_eError : NBS.ERROR;
   TCPServer_xError : BOOL;
   TCPServer_hServer : NBS.CAA.HANDLE;
   TCPConnection : NBS.TCP_Connection;
   TCPConnection_xDone: BOOL;
   TCPConnection_eError : NBS.ERROR;
   TCPConnection_xActive : BOOL;
   TCPWrite : NBS.TCP_Write;
   TCPWrite_xDone : BOOL;
   TCPWrite_xBusy : BOOL;
   TCPWrite_eError : NBS.ERROR;
   TCPWrite_xError : BOOL;
END_VAR
---PROGRAM---
IF bFirst THEN
   bFirst := FALSE;
   // CoDeSys Automation Alliance (CAA) Interfaces - NetBaseServices (NBS)
   NBS_IP_Adress.sAddr := '192.168.178.39';
   TCPServer(
      xEnable := TRUE,
      ipAddr := NBS_IP_Adress,
      uiPort := 61002,
      xDone => TCPServer_xDone,
      xBusy => TCPServer_xBusy,
      eError => TCPServer_eError,
      xError => TCPServer_xError,
END_IF
My_Data[0] := My_Data[0]+1;
My_Data[1] := My_Data[1]+1;
My_Data[2] := My_Data[2]+1;
My_Data[3] := My_Data[3]+1;
My_Data[4] := My_Data[4]+1;
TCPConnection(
   xEnable := TRUE,
   hServer := TCPServer.hServer,
   xDone => TCPConnection_xDone,
   eError => TCPConnection_eError,
   xActive => TCPConnection_xActive
IF TCPConnection.xDone THEN
   TCPWrite(
      xExecute := TRUE,
      hConnection := TCPConnection.hConnection,
      pData := ADR(My_Data),
      szSize := SIZEOF(My_Data),
      xDone => TCPWrite_xDone,
      xBusy => TCPWrite_xBusy,
      xError => TCPWrite_xError,
      eError => TCPWrite_eError
END_IF
Do you have an idea what is wrong with my implementation?
Thanks in advance for your kind support.
Regards,
Robert
PostPosted: Wed Jul 11, 2012 6:21 am
I'm not 100% sure, but here some things that might help:
- Always call the TCPServer FB (not just the first scan) with xEnable TRUE.
- Enable the TCPConnection when the TCPServer handle is not invalid or 0.
- Execute the TCPWrite FB when the TCPConnection is Active (not when it is done)
- An Execute input of the FB is a trigger to start it, therefore the data is only send once in your application. Replace the TRUE for a puls generator or something similar.
PostPosted: Wed Jul 11, 2012 4:53 pm
Hey TimvH,
"Always call the TCPServer FB (not just the first scan) with xEnable TRUE" helped me out!
Thank you for your help!
PostPosted: Sun Jul 29, 2012 7:46 pm
I would recommend using the OsCat Network Library it has been tested and validated. You can use the IP_CONTROL FB's to implement you own TCP SERVER.
You have to be signed in to download. This has been updated for CoDeSys V3.
http://www.oscat.de/community/index.php ... 784.0.html
The Original SoMachine Ninja
PostPosted: Thu Dec 20, 2012 10:34 am
Hello Robinston,
I tried your code (and I ran TCPServer always, as it was recommended, not only in the first run), but in my TCPWrite FB, I get "Invalid Handle", even if I try the other recommended issues, posted by TimvH.
Did you only deleted the IF bfirst THEN-Loop - or did you some other changes in your code until it worked?
Thanks in advance for your kind help.
Best Regards
Ruwen
