First you have to create a structure:
In CoDeSys you have to add to the application a "DUT: Data Unit Type". Give it a name and select Structure.
Now you can add the (standard) variables which are part of this structure.
In your POU you can add a new variable of the structure which you have created. e.g.:
aStruct:ARRAY[0..constant]OFmyStructure;
In this case myStructure is the name of your new type.
aStruct is the instance of this struct.
In CoDeSys you can use the variable: aStruct[index].standardVar
You have to put the instance of the structure (EQ_SDI_TEMP_SONDA : ARARAY[0..5] OF EQ_SDI_TEMP_SONDA_ATT;) in the POU or Global Variable List. Not in the Structure itself.
I want to implement that program written in C with CoDeSys written in ST language. I don't know how to do "EQ_SDI_TEMP_SONDA[i].m_TempNOK".
The program:
OBJECT ATTRIBUTES /
struct EQ_SDI_TEMP_SONDA_ATT EQ_SDI_TEMP_SONDA[c_EQ_SDI_TEMP_SONDA_MAX_OBJ];
METHODS /
---- EQ_SDI_TEMP_SONDA_SetInput ----------------------------------*
void EQ_SDI_TEMP_SONDA_SetInput(CS_UNSIGNED8 i,
CS_UNSIGNED16 In1, / Entrada temperatura SDI. /
CS_BOOLEAN1 In1Ok, / Validez de la entrada. /
CS_UNSIGNED16 In2 / Entrada temperatura PLC. /
/---- Local Variables --------------/
/---- Comprobacion de index --------------/
PLC_CheckIndex(EQ_SDI_TEMP_SONDA_SetInput, i, c_EQ_SDI_TEMP_SONDA_MAX_OBJ);
/---- Timers -----------------------/
/---- Code -------------------------/
/---- Former values -------------------------/
------- EQ_SDI_TEMP_SONDA_GetValue ------------------------------
CS_BOOLEAN1 EQ_SDI_TEMP_SONDA_GetValue(CS_UNSIGNED8 i) { / Devuelve el valor. /
I make this but isn't correct.
TYPE
EQ_SDI_TEMP_SONDA_ATT:
STRUCT
m_TempNOK : BOOL;
END_STRUCT;
END_TYPE
