Error WSTRING_TO_INT
Anonymous
2012-06-25
2012-06-26
  • Anonymous - 2012-06-25
    Originally created by: Matthias S.
    I have a problem with the following code:
    NumberInString : WSTRING(20) := "16#a";
    NumberΒ  Β  Β  Β  Β : INT;
    Number := WSTRING_TO_INT(NumberInString);
    I expect the value decimal 10 but I get the value 37.
    What am I doing wrong?
    Thanks in advance for your help.
    Best regards,
    Matthias
  • shooter - 2012-06-25
    wstring name is fault and the first character is a 1 giving 37
    use only the A int he string
  • TimvH
    TimvH - 2012-06-25
    Hi Matthias,
    You should use capital letters. "16#A" will return 10.
  • Anonymous - 2012-06-26
    Hello TimvH, shooter,
    thank you for your help.
    The solution is OK, but I think "a" and "A" should both work.
    But for now it's OK.
    Thanks,
    Matthias
